[Live-demo] Does your application work on the click2try GISVM?
arun.s at tecnics.com arun.s at tecnics.com
Thu Oct 15 13:26:41 EDT 2009
We are exploring this.
We will update you in next mail.
Thanks
Arun Sharma
Click2try
Sent: Thursday, October 15, 2009 10:44 PM
To: "Dane Springmeyer" <blake at hailmail.net>
Subject: Re: [Live-demo] Does your application work on the click2try GISVM?
Running `strace python` gives an Illegal Instruction:
http://dpaste.com/107722/
I wonder if the read-only user mode is the culprit.
Dane
On Oct 15, 2009, at 9:51 AM, Dane Springmeyer wrote:
I just tried the latest VM '20-74' and now see a Segmentation Fault when
running the default python.
Open a terminal and type 'python' and this is what you get:
user at osgeo-gisvm20-74:~$ python
Segmentation fault
but python2.5 works:
user at osgeo-gisvm20-74:~$ python2.5
>>> # all good...
Really odd, I've never seen a segfault like this with python after just
starting the interpreter.
Dane
On Oct 15, 2009, at 9:00 AM, Aneel wrote:
Hello OSGeo Team,
We have fixed issues and latest click2try-GISVM (osgeo-gisvm20-74) is
available for testing at www.click2try.com.
Know Issue: (Reported to Jody)
/usr/bin/udig: line 29:  3026 Segmentation fault      $PRGDIR/udig_internal
-data ~/uDigWorkspace $@
Please let us know if any more issues after testing.
Thanks & Regards
Aneel
click2try
On Thu, 2009-10-15 at 12:32 +0530, Aneel wrote:
Hello Team,
Maintenance and bug fix activity is going on click2try-GISVM. Please
don't try the GISVM on click2try for some time. Once we are done with
maintenance activity, we will post update on this mailing list.
Regards
Aneel
On Thu, 2009-10-15 at 14:47 +1100, Cameron Shorter wrote:
> Arun,
> I've lost track of where geonetwork is up to. I think you had it fixed,
> and Simon/Jeroen were just updating the automated script for future.
> Simon, are you able to confirm this?
> arun.s at tecnics.com wrote:
> > Hello Cameron,
> > After reviewing this mail , i think there is something more to be done
> > to fix this in click2try vm (not sure).
> > It will be good if (any) steps we need to do on click2try to fix this
> > issue then please inform us.
> > FYI , we have already applied the steps metioned by Jeron on currently
> > running vm.
> > Arun Sharma
> > Click2try
> > *From*: "Simon Pigot" <Simon.Pigot at csiro.au>
> > *Sent*: Thursday, October 15, 2009 6:33 AM
> > *To*: "Cameron Shorter" <cameron.shorter at lisasoft.com>
> > *Subject*: Re: [Live-demo] Does your application work on the click2try
> > GISVM?
> > What puzzles me about all this is that the changes Jeroen has made to
> > the shortcut scripts were actually the way in which the shortcut
scripts
> > were originally submitted!
> > Cameron, the chown command is in the install_geonetwork.sh already!
> > The problems seem to have been caused by a decision someone made to
> > change the uid/gid of user/password (when? how? why?) - is it still
> > necessary to run the scripts with a sudo to user?
> > Cheers,
> > Simon
> > > Jeroen,
> > > I hope that we can apply your fixes to the geonetwork install
scripts.
> > > If you have not updated the install_geonetwork.sh , can you please
> > > describe the issue and fix in the issue tracker, so that we can
update
> > > it before we go through the next release cycle.
http://trac.osgeo.org/osgeo/query?group=status&component=LiveDVD&order=prior
ity
> > > Jeroen Ticheler wrote:
> > >> Hi Aneel,
> > >> These are the changes I did:
> > >> from the root of the geonetwork application:
> > >> sudo chown -R user:user *
> > >> In the shortcuts that start and stop GeoNetwork I removed the first
> > >> part of the command, just leaving the part:
> > >> /usr/lib/geonetwork/bin/start-geonetwork.sh
> > >> or
> > >> /usr/lib/geonetwork/bin/stop-geonetwork.sh
> > >> That's all.
> > >> Ciao,
> > >> Jeroen
> > >> ____________________________________________________
> > >> Jeroen Ticheler
> > >> De Braakweg 12a
> > >> 7524 PH Enschede
> > >> Tel/Fax: +31 (0)53 7370049
> > >> Mobile: +31 (0)6 81286572
> > >> http://www.ticheler.net
> > >> Please consider the environment before printing this email.
> > >> On Oct 14, 2009, at 1:11 PM, Aneel wrote:
> > >>> Hello Jeroen,
> > >>> Please give us the steps you did to fix these issues. Whatever you
> > doing
> > >>> is specific to particular instance only. We have to fix them at
> > >>> application level to make permanent.
> > >>> Regards
> > >>> Aneel
> > >>> click2try
> > >>> On Wed, 2009-10-14 at 13:05 +0200, Jeroen Ticheler wrote:
> > >>>> Last thing, I also fixed the start and stop shortcuts. They should
> > >>>> point directly to the start and stop scripts and not go through
the
> > >>>> launchhelper script.
> > >>>> Greetings,
> > >>>> Jeroen
> > >>>> On Oct 14, 2009, at 12:46 PM, Aneel wrote:
> > >>>>> Hello Jeroen,
Please
> > >>>>> don't try the GISVM on click2try for some time.. Once we have
> > done with
> > >>>>> Regards
> > >>>>> Aneel
> > >>>>> click2try
> > >>>>> On Wed, 2009-10-14 at 12:41 +0200, Jeroen Ticheler wrote:
> > >>>>>> Hi Tom,
> > >>>>>> I tried again several times today. I got some steps further, but
> > >>>>>> can't
> > >>>>>> get on to the desktop :-( I use "user/user" as account/pw but
> > then I
> > >>>>>> get an error as shown on the screenshot. Is there a way to use
SSH?
> > >>>>>> Kind regards,
> > >>>>>> Jeroen
> > >>>>>> Jeroen Ticheler
> > >>>>>> De Braakweg 12a
> > >>>>>> 7524 PH Enschede
> > >>>>>> On Oct 14, 2009, at 1:22 AM, Tom Callaghan wrote:
> > >>>>>>> Hi Jaroen,
> > >>>>>>> Maybe I can help you with your connection issues. The message
> > >>>>>>> "Public Internet Access: Yes, Not available" refers to
something
> > >>>>>>> that has not yet been set up for this VM. This is not a
> > problem and
> > >>>>>>> you should still be able to access the VM. When you attempted
to
> > >>>>>>> connect, had you highlighted the VM osgeo-gisvm20-25 and
click2ed
> > >>>>>>> the LAUNCH button? If so, what happens? Do you see a light
purple
> > >>>>>>> screen with a progress bar across the top? Do you receive a
> > message
> > >>>>>>> for installing a click2try java applet? Does a frame with a
page
> > >>>>>>> not found appear on the left side of the screen with a title
bar
> > >>>>>>> "quickstart guide"?
> > >>>>>>> Tom
> > >>>>>>> From: Jeroen Ticheler [mailto:Jeroen at Ticheler.net]
> > >>>>>>> Sent: Tuesday, October 13, 2009 5:41 PM
> > >>>>>>> To: Aneel
> > >>>>>>> Cc: Cameron Shorter; Ricardo Pinho; Tom Callaghan; Arun Sharma
> > >>>>>>> Tecnics
> > click2try
> > >>>>>>> GISVM?
> > >>>>>>> Hi Aneel,
> > >>>>>>> I tried to connect and have a look. I can't get access, maybe
> > >>>>>>> because someone else is using the VM, is that correct? I read
> > >>>>>>> "Public Internet Access: Yes, Not available" and I see one user
> > >>>>>>> online.
> > >>>>>>> Concerning the problem, the first two lines are normal for a
very
> > >>>>>>> first time startup. The following three lines are not and
indicate
> > >>>>>>> that the permissions of the account running the application
don't
> > >>>>>>> allow writing to the logs directory. Most likely the same is
true
> > >>>>>>> for some other directories that GeoNetwork needs to be able to
> > write
> > >>>>>>> to. I suggest reviewing the privileges of the process owner to
> > >>>>>>> ensure that write privileges are given to the GeoNetwork
> > application
> > >>>>>>> folders.
> > >>>>>>> Let me know if I can help further.
> > >>>>>>> Kind regards,
> > >>>>>>> Jeroen
> > >>>>>>> ps. I will be on my way to Sydney from Thursday morning onwards
> > >>>>>>> (Amsterdam time zone).
> > >>>>>>> On Oct 13, 2009, at 8:54 PM, Aneel wrote:
> > >>>>>>> Issue2: (GeoNetwork - it doesn't work)
> > >>>>>>> Launching /usr/lib/geonetwork/bin/start-geonetwork.sh
> > >>>>>>> rm: cannot remove `logs/*request.log*': No such file or
directory
> > >>>>>>> rm: cannot remove `logs/output.log': No such file or directory
> > >>>>>>> mv: cannot stat `logs/geonetwork.log.*': No such file or
directory
> > >>>>>>> mv: cannot stat `logs/intermap.log.*': No such file or
directory
> > >>>>>>> mv: cannot stat `logs/geoserver.log.*': No such file or
directory
Live-demo mailing list
Live-demo at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/live-demo
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20091015/d26bba87/attachment-0001.html
More information about the Live-demo mailing list
