[Live-demo] Does your application work on the click2try GISVM?
Jody Garnett jody.garnett at gmail.com
Thu Oct 15 18:37:11 EDT 2009
Morning Aneel:
On of the udig-devel (Andrea is CCed) has asked what the contents of
your udig script is; I went looking on the live dvd and could not find
where things were located.
Okay mark helped me; normal udig stuff seems to occur in /usr/lib/udig
Jody
On Fri, Oct 16, 2009 at 8:23 AM, Jody Garnett <jody.garnett at gmail.com> wrote:
> I have passed your email on to the udig-devel list.
> What do you mean by "next onwards"?
> It does sound like you are running into permission problems. The command
> line parameters for uDig are documented here.
>http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse.platform.doc.isv/reference/misc/runtime-options.html
> My guess is that it wants to write into a directory which it cannot?
> I believe that this discussion has occurred too late before the conference
> for me to help you; you will need to distribute without uDig working. Either
> remove it or place a note in the read me.
> Jody
> On 15/10/2009, at 11:25 PM, Aneel wrote:
> Hello Jody,
> uDig is throwing following error while startup.
> error:
> /usr/bin/udig: line 29:  3026 Segmentation fault      $PRGDIR/udig_internal
> -data ~/uDigWorkspace $@
> Note: If I have applied the "chown -R user.user /usr/lib/udig" command at
> first time, then it works fine. Next onwards throwing above error
> Please guide me to resolve this issue.
> Regards
> Aneel
> On Thu, 2009-10-15 at 10:29 +1100, Jody Garnett wrote:
> Don't ignore this ... this is the actual testing results:
> Testing in safari resulted in:
> - geoserver start and install looks good; tasmania map renders
>  (complained about previous firefox session)
> - udig starts; renders clouds and countries.shp
> - renders WMS from geoserver; supported DnD from firefox to uDig catalog
> - not able to right click on anything; that seems to be taken up by
> the browser not the java applet
> - mouse interaction was not response enough to supported editing,
> could not drag a point; indeed pointer would get stuck at a particular
> location; although it would change shape depending on what you were
> actually hovering over.
> So about 90% here; enough to demo; not enough to use.
> Jody
> On Tue, Oct 13, 2009 at 1:28 PM, Jody Garnett <jody.garnett at gmail.com>
> wrote:
>> Okay figured it out ...
>> - chrome did not work
>> - safari on mac did not work
>> - it crashed firefox on mac
>> Trick was to disable the pop up blockers; and then provide access
>> rights to java app
>> Jody
>> On Tue, Oct 13, 2009 at 10:03 AM, Jody Garnett <jody.garnett at gmail.com>
>> wrote:
>>>>>> Log in using
>>>>>> user id: osgeo password: livedemo
>>>>>> Once logged in, navigate to My Dashboard/Applications Manager.  You
>>>>>> will
>>>>>> see a VM named osgeo-gisvmsl-2.
>>>> The Application Manager link does not function for me; it brings up an
>>>> embedded frame showing a broken link.
>>> In firefox it shows the connection timing out ... The server at
>>> scooter.dev.presage-tech.com is taking too long to respond.
>>> Jody
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
More information about the Live-demo mailing list
