[Live-demo] Does your application work on the click2try GISVM?
Jody Garnett jody.garnett at gmail.com
Fri Oct 16 01:22:47 EDT 2009
So I am a bit unclear about "next onward" still; when start up again;
you are a different user each time? But some changes from the previous
user will be around?
I think I have a clue then - the configuration directory is created by
the first user; and cannot be read/modified by the second?
Andrea may be able to help construct a better set of command line
parameters that in effect allow multiple users to share this
application?
Jody
On Fri, Oct 16, 2009 at 2:47 PM, arun.s at tecnics.com <arun.s at tecnics.com> wrote:
> Hello Jody,
> Just thought to share my thougts regarding this issue.
> "Next onwards" means when a particular instance of vm is created and
> persmission is set using command "chown -R user.user /usr/lib/udig" , we can
> run "udig"  and application runs perfectly. We can close the udig
> application and start again. Starting udig again also works for us.
> When we close the virtual machine and saved it. After opening the
> vm udig does not work and we get seg fault error.
> Yes, udig stuff is present in /usr/lib/udig directory.
> Arun sharma
> Click2try
> ________________________________
> From: "Jody Garnett" <jody.garnett at gmail.com>
> Sent: Friday, October 16, 2009 4:08 AM
> To: "Aneel" <aneel.r at tecnics.com>, "andrea antonello"
> <andrea.antonello at gmail.com>
> Subject: Re: [Live-demo] Does your application work on the click2try GISVM?
> Morning Aneel:
> On of the udig-devel (Andrea is CCed) has asked what the contents of
> your udig script is; I went looking on the live dvd and could not find
> where things were located.
> Okay mark helped me; normal udig stuff seems to occur in /usr/lib/udig
> Jody
> On Fri, Oct 16, 2009 at 8:23 AM, Jody Garnett wrote:
>> I have passed your email on to the udig-devel list.
>> What do you mean by "next onwards"?
>> It does sound like you are running into permission problems. The command
>> line parameters for uDig are documented here.
>>http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse.platform.doc.isv/reference/misc/runtime-options.html
>> My guess is that it wants to write into a directory which it cannot?
>> I believe that this discussion has occurred too late before the conference
>> for me to help you; you will need to distribute without uDig working.
>> Either
>> remove it or place a note in the read me.
>> Jody
>> On 15/10/2009, at 11:25 PM, Aneel wrote:
>> Hello Jody,
>> uDig is throwing following error while startup.
>> error:
>> /usr/bin/udig: line 29:  3026 Segmentation fault
>> $PRGDIR/udig_internal
>> -data ~/uDigWorkspace $@
>> Note: If I have applied the "chown -R user.user /usr/lib/udig" command at
>> first time, then it works fine. Next onwards throwing above error
>> Please guide me to resolve this issue.
>> Regards
>> Aneel
>> On Thu, 2009-10-15 at 10:29 +1100, Jody Garnett wrote:
>> Don't ignore this ... this is the actual testing results:
>> Testing in safari resulted in:
>> - geoserver start and install looks good; tasmania map renders
>> (complained about previous firefox session)
>> - udig starts; renders clouds and countries.shp
>> - renders WMS from geoserver; supported DnD from firefox to uDig catalog
>> - not able to right click on anything; that seems to be taken up by
>> the browser not the java applet
>> - mouse interaction was not response enough to supported editing,
>> could not drag a point; indeed pointer would get stuck at a particular
>> location; although it would change shape depending on what you were
>> actually hovering over.
>> So about 90% here; enough to demo; not enough to use.
>> Jody
>> On Tue, Oct 13, 2009 at 1:28 PM, Jody Garnett
>> wrote:
>>> Okay figured it out ...
>>> - chrome did not work
>>> - safari on mac did not work
>>> - it crashed firefox on mac
>>> Trick was to disable the pop up blockers; and then provide access
>>> rights to java app
>>> Jody
>>> On Tue, Oct 13, 2009 at 10:03 AM, Jody Garnett
>>> wrote:
>>>>>>> Log in using
>>>>>>> user id: osgeo password: livedemo
>>>>>>> Once logged in, navigate to My Dashboard/Applications Manager.  You
>>>>>>> will
>>>>>>> see a VM named osgeo-gisvmsl-2.
>>>>> The Application Manager link does not function for me; it brings up an
>>>>> embedded frame showing a broken link.
>>>> In firefox it shows the connection timing out ... The server at
>>>> scooter.dev.presage-tech.com is taking too long to respond.
>>>> Jody
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
More information about the Live-demo mailing list
