[Live-demo] Does your application work on the click2try GISVM?
Arun Sharma Tecnics arun.s at tecnics.com
Fri Oct 16 08:18:02 EDT 2009
Hello Jody,
We are trying to login with same user "user" on gisvm but sometimes it
works and sometime it does not work.
It will be good if "Andrea" can give a try to run the vm and check once.
Here are the steps.
          Click here http://www.click2try.com to go to click2try.com
2.          Navigate to Web Development/Geospacial/Arramagong GISVM
3.          Click the "Try this Application" button
         Click the "Start My Application" button
       Once Vm is launched. Login into vm using user "user" and password
as "user".
       Click "udig" icon on desktop.
Above steps will allow anyone to have single non persistence vm but if
we want persistence vm then we have to create a registered user and then
try this appliance.
Regards,
Arun Sharma
Click2try
Jody Garnett wrote:
> So I am a bit unclear about "next onward" still; when start up again;
> you are a different user each time? But some changes from the previous
> user will be around?
> I think I have a clue then - the configuration directory is created by
> the first user; and cannot be read/modified by the second?
> Andrea may be able to help construct a better set of command line
> parameters that in effect allow multiple users to share this
> application?
> Jody
> On Fri, Oct 16, 2009 at 2:47 PM, arun.s at tecnics.com <arun.s at tecnics.com> wrote:
>> Hello Jody,
>> Just thought to share my thougts regarding this issue.
>> "Next onwards" means when a particular instance of vm is created and
>> persmission is set using command "chown -R user.user /usr/lib/udig" , we can
>> run "udig"  and application runs perfectly. We can close the udig
>> application and start again. Starting udig again also works for us.
>> When we close the virtual machine and saved it. After opening the
>> vm udig does not work and we get seg fault error.
>> Yes, udig stuff is present in /usr/lib/udig directory.
>> Arun sharma
>> Click2try
>> ________________________________
>> From: "Jody Garnett" <jody.garnett at gmail.com>
>> Sent: Friday, October 16, 2009 4:08 AM
>> To: "Aneel" <aneel.r at tecnics.com>, "andrea antonello"
>> <andrea.antonello at gmail.com>
>> Subject: Re: [Live-demo] Does your application work on the click2try GISVM?
>> Morning Aneel:
>> On of the udig-devel (Andrea is CCed) has asked what the contents of
>> your udig script is; I went looking on the live dvd and could not find
>> where things were located.
>> Okay mark helped me; normal udig stuff seems to occur in /usr/lib/udig
>> Jody
>> On Fri, Oct 16, 2009 at 8:23 AM, Jody Garnett wrote:
>>> I have passed your email on to the udig-devel list.
>>> What do you mean by "next onwards"?
>>> It does sound like you are running into permission problems. The command
>>> line parameters for uDig are documented here.
>>> - http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse.platform.doc.isv/reference/misc/runtime-options.html
>>> My guess is that it wants to write into a directory which it cannot?
>>> I believe that this discussion has occurred too late before the conference
>>> for me to help you; you will need to distribute without uDig working.
>>> Either
>>> remove it or place a note in the read me.
>>> Jody
>>> On 15/10/2009, at 11:25 PM, Aneel wrote:
>>> Hello Jody,
>>> uDig is throwing following error while startup.
>>> error:
>>> /usr/bin/udig: line 29:  3026 Segmentation fault
>>> $PRGDIR/udig_internal
>>> -data ~/uDigWorkspace $@
>>> Note: If I have applied the "chown -R user.user /usr/lib/udig" command at
>>> first time, then it works fine. Next onwards throwing above error
>>> Please guide me to resolve this issue.
>>> Regards
>>> Aneel
>>> On Thu, 2009-10-15 at 10:29 +1100, Jody Garnett wrote:
>>> Don't ignore this ... this is the actual testing results:
>>> Testing in safari resulted in:
>>> - geoserver start and install looks good; tasmania map renders
>>> (complained about previous firefox session)
>>> - udig starts; renders clouds and countries.shp
>>> - renders WMS from geoserver; supported DnD from firefox to uDig catalog
>>> - not able to right click on anything; that seems to be taken up by
>>> the browser not the java applet
>>> - mouse interaction was not response enough to supported editing,
>>> could not drag a point; indeed pointer would get stuck at a particular
>>> location; although it would change shape depending on what you were
>>> actually hovering over.
>>> So about 90% here; enough to demo; not enough to use.
>>> Jody
>>> On Tue, Oct 13, 2009 at 1:28 PM, Jody Garnett
>>> wrote:
>>>> Okay figured it out ...
>>>> - chrome did not work
>>>> - safari on mac did not work
>>>> - it crashed firefox on mac
>>>> Trick was to disable the pop up blockers; and then provide access
>>>> rights to java app
>>>> Jody
>>>> On Tue, Oct 13, 2009 at 10:03 AM, Jody Garnett
>>>> wrote:
>>>>>>>> Log in using
>>>>>>>> user id: osgeo password: livedemo
>>>>>>>> Once logged in, navigate to My Dashboard/Applications Manager.  You
>>>>>>>> will
>>>>>>>> see a VM named osgeo-gisvmsl-2.
>>>>>> The Application Manager link does not function for me; it brings up an
>>>>>> embedded frame showing a broken link.
>>>>> In firefox it shows the connection timing out ... The server at
>>>>> scooter.dev.presage-tech.com is taking too long to respond.
>>>>> Jody
>>> Live-demo mailing list
>>> Live-demo at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/live-demo
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20091016/81a412a5/attachment.html
More information about the Live-demo mailing list
