[Live-demo] Re: [About python issue] Does your application work on the click2try GISVM?
Tom Callaghan tom.callaghan at click2try.com
Fri Oct 16 18:47:04 EDT 2009
Hi Dane,
Arun is the right person to work with on this one.  I do not want to
shortcut anything you are doing with him.  But, I did observe something.
First, I started a new GISVM virtual machine on click2try as a non-logged in
user.  I logged into the GISVM desktop as the user "user".  I am able to
open a terminal window.  Then, I notice that if I try to start Mapnik from
the icon it fails the first time.  But, if I try to start it again, it
succeeds.
After that, I notice that uDig seems to start up successfully.
I don't know if this helps or not.
Regards,
Tom
[mailto:live-demo-bounces at lists.osgeo.org] On Behalf Of Dane Springmeyer
Sent: Friday, October 16, 2009 1:53 PM
To: arun.s at tecnics.com
Cc: tom.callaghan at presage-tech.com; live-demo at lists.osgeo.org; Cameron
Shorter; tech at wildintellect.com
Subject: [Live-demo] Re: [About python issue] Does your application work on
Hello Arun,
I just tested the VM linked from the public announcement.
It looks as if you have restricted the use of the terminal?  That
essentially breaks the Mapnik demo because it launches in a terminal window
to show the server process. I also cannot open a terminal on the VM now to
be able to debug...
If I click the icon "Start Mapnik & TileLite" I get:
"Failed to Execute default Terminal Emulator: Input/Output Error"
Also, double-clicking the uDIG icon does nothing.
Dane
On Oct 16, 2009, at 10:13 AM, arun.s at tecnics.com wrote:
Thanks Dane for updating us.
Please let us know in case you find any issue.
Regards
Arun
  _____
Sent: Friday, October 16, 2009 9:03 PM
To: "Arun Sharma Tecnics" <arun.s at tecnics.com>
Subject: Re: [About python issue] Does your application work on the
click2try GISVM?
Hello Arun,
Yes, the new VM works with Python 26. And therefore the Mapnik Python 2.6
bindings now work.
And with this small fix (which I've been waiting to make), the demo
application now works perfectly:
http://trac.osgeo.org/osgeo/changeset/2684
Thanks!
Dane
On Oct 16, 2009, at 5:07 AM, Arun Sharma Tecnics wrote:
Hello Dane,
Could you please help us by trying again "python" command from new instance
vm rather then using existing '20-74'. ?
Arun Sharma
Click2try
Dane Springmeyer wrote:
Running `strace python` gives an Illegal Instruction:
http://dpaste.com/107722/
I wonder if the read-only user mode is the culprit.
Dane
On Oct 15, 2009, at 9:51 AM, Dane Springmeyer wrote:
I just tried the latest VM '20-74' and now see a Segmentation Fault when
running the default python.
Open a terminal and type 'python' and this is what you get:
user at osgeo-gisvm20-74:~$ python
Segmentation fault
but python2.5 works:
user at osgeo-gisvm20-74:~$ python2.5
>>> # all good...
Really odd, I've never seen a segfault like this with python after just
starting the interpreter.
Dane
On Oct 15, 2009, at 9:00 AM, Aneel wrote:
Hello OSGeo Team,
We have fixed issues and latest click2try-GISVM (osgeo-gisvm20-74) is
available for testing at www.click2try.com. <http://www.click2try.com>
Know Issue: (Reported to Jody)
/usr/bin/udig: line 29:  3026 Segmentation fault      $PRGDIR/udig_internal
-data ~/uDigWorkspace $@
Please let us know if any more issues after testing.
Thanks & Regards
Aneel
click2try
On Thu, 2009-10-15 at 12:32 +0530, Aneel wrote:
Hello Team,
Maintenance and bug fix activity is going on click2try-GISVM. Please
don't try the GISVM on click2try for some time. Once we are done with
maintenance activity, we will post update on this mailing list.
Regards
Aneel
On Thu, 2009-10-15 at 14:47 +1100, Cameron Shorter wrote:
> Arun,
> I've lost track of where geonetwork is up to. I think you had it fixed,
> and Simon/Jeroen were just updating the automated script for future.
> Simon, are you able to confirm this?
> > Hello Cameron,
> > After reviewing this mail , i think there is something more to be done
> > to fix this in click2try vm (not sure).
> > It will be good if (any) steps we need to do on click2try to fix this
> > issue then please inform us.
> > FYI , we have already applied the steps metioned by Jeron on currently
> > running vm.
> > Arun Sharma
> > Click2try
> > *From*: "Simon Pigot" <Simon.Pigot at csiro.au>
> > *Sent*: Thursday, October 15, 2009 6:33 AM
> > *To*: "Cameron Shorter" <cameron.shorter at lisasoft.com>
> > *Subject*: Re: [Live-demo] Does your application work on the click2try
> > GISVM?
> > What puzzles me about all this is that the changes Jeroen has made to
> > the shortcut scripts were actually the way in which the shortcut scripts
> > were originally submitted!
> > Cameron, the chown command is in the install_geonetwork.sh already!
> > The problems seem to have been caused by a decision someone made to
> > change the uid/gid of user/password (when? how? why?) - is it still
> > necessary to run the scripts with a sudo to user?
> > Cheers,
> > Simon
> > > Jeroen,
> > > I hope that we can apply your fixes to the geonetwork install scripts.
> > > If you have not updated the install_geonetwork.sh , can you please
> > > describe the issue and fix in the issue tracker, so that we can update
> > > it before we go through the next release cycle.
> > http://trac.osgeo.org/osgeo/query?group=status
<http://trac.osgeo.org/osgeo/query?group=status&component=LiveDVD&order=prio
rity> &component=LiveDVD&order=priority
> > > Jeroen Ticheler wrote:
> > >> Hi Aneel,
> > >> These are the changes I did:
> > >> from the root of the geonetwork application:
> > >> sudo chown -R user:user *
> > >> In the shortcuts that start and stop GeoNetwork I removed the first
> > >> part of the command, just leaving the part:
> > >> /usr/lib/geonetwork/bin/start-geonetwork.sh
> > >> or
> > >> /usr/lib/geonetwork/bin/stop-geonetwork.sh
> > >> That's all.
> > >> Ciao,
> > >> Jeroen
> > >> ____________________________________________________
> > >> Jeroen Ticheler
> > >> De Braakweg 12a
> > >> 7524 PH Enschede
> > >> Tel/Fax: +31 (0)53 7370049
> > >> Mobile: +31 (0)6 81286572
> > >> http://www.ticheler.net
> > >> Please consider the environment before printing this email.
> > >> On Oct 14, 2009, at 1:11 PM, Aneel wrote:
> > >>> Hello Jeroen,
> > >>> Please give us the steps you did to fix these issues. Whatever you
> > doing
> > >>> is specific to particular instance only. We have to fix them at
> > >>> application level to make permanent.
> > >>> Regards
> > >>> Aneel
> > >>> click2try
> > >>> On Wed, 2009-10-14 at 13:05 +0200, Jeroen Ticheler wrote:
> > >>>> Last thing, I also fixed the start and stop shortcuts. They should
> > >>>> point directly to the start and stop scripts and not go through the
> > >>>> launchhelper script.
> > >>>> Greetings,
> > >>>> Jeroen
> > >>>> On Oct 14, 2009, at 12:46 PM, Aneel wrote:
> > >>>>> Hello Jeroen,
Please
> > >>>>> don't try the GISVM on click2try for some time.. Once we have
> > done with
> > >>>>> Regards
> > >>>>> Aneel
> > >>>>> click2try
> > >>>>> On Wed, 2009-10-14 at 12:41 +0200, Jeroen Ticheler wrote:
> > >>>>>> Hi Tom,
> > >>>>>> I tried again several times today. I got some steps further, but
> > >>>>>> can't
> > >>>>>> get on to the desktop :-( I use "user/user" as account/pw but
> > then I
> > >>>>>> get an error as shown on the screenshot. Is there a way to use
SSH?
> > >>>>>> Kind regards,
> > >>>>>> Jeroen
> > >>>>>> Jeroen Ticheler
> > >>>>>> De Braakweg 12a
> > >>>>>> 7524 PH Enschede
> > >>>>>> On Oct 14, 2009, at 1:22 AM, Tom Callaghan wrote:
> > >>>>>>> Hi Jaroen,
> > >>>>>>> Maybe I can help you with your connection issues. The message
> > >>>>>>> "Public Internet Access: Yes, Not available" refers to something
> > >>>>>>> that has not yet been set up for this VM. This is not a
> > problem and
> > >>>>>>> you should still be able to access the VM. When you attempted to
> > >>>>>>> connect, had you highlighted the VM osgeo-gisvm20-25 and
click2ed
> > >>>>>>> the LAUNCH button? If so, what happens? Do you see a light
purple
> > >>>>>>> screen with a progress bar across the top? Do you receive a
> > message
> > >>>>>>> for installing a click2try java applet? Does a frame with a page
> > >>>>>>> not found appear on the left side of the screen with a title bar
> > >>>>>>> "quickstart guide"?
> > >>>>>>> Tom
> > >>>>>>> From: Jeroen Ticheler [mailto:Jeroen at Ticheler.net]
> > >>>>>>> Sent: Tuesday, October 13, 2009 5:41 PM
> > >>>>>>> To: Aneel
> > >>>>>>> Cc: Cameron Shorter; Ricardo Pinho; Tom Callaghan; Arun Sharma
> > >>>>>>> Tecnics
> > >>>>>>> Subject: Re: [Live-demo] Does your application work on the
> > click2try
> > >>>>>>> GISVM?
> > >>>>>>> Hi Aneel,
> > >>>>>>> I tried to connect and have a look. I can't get access, maybe
> > >>>>>>> because someone else is using the VM, is that correct? I read
> > >>>>>>> "Public Internet Access: Yes, Not available" and I see one user
> > >>>>>>> online.
> > >>>>>>> Concerning the problem, the first two lines are normal for a
very
> > >>>>>>> first time startup. The following three lines are not and
indicate
> > >>>>>>> that the permissions of the account running the application
don't
> > >>>>>>> allow writing to the logs directory. Most likely the same is
true
> > >>>>>>> for some other directories that GeoNetwork needs to be able to
> > write
> > >>>>>>> to. I suggest reviewing the privileges of the process owner to
> > >>>>>>> ensure that write privileges are given to the GeoNetwork
> > application
> > >>>>>>> folders.
> > >>>>>>> Let me know if I can help further.
> > >>>>>>> Kind regards,
> > >>>>>>> Jeroen
> > >>>>>>> ps. I will be on my way to Sydney from Thursday morning onwards
> > >>>>>>> (Amsterdam time zone).
> > >>>>>>> On Oct 13, 2009, at 8:54 PM, Aneel wrote:
> > >>>>>>> Issue2: (GeoNetwork - it doesn't work)
> > >>>>>>> Launching /usr/lib/geonetwork/bin/start-geonetwork.sh
> > >>>>>>> rm: cannot remove `logs/*request.log*': No such file or
directory
> > >>>>>>> rm: cannot remove `logs/output.log': No such file or directory
> > >>>>>>> mv: cannot stat `logs/geonetwork.log.*': No such file or
directory
> > >>>>>>> mv: cannot stat `logs/intermap.log.*': No such file or directory
> > >>>>>>> mv: cannot stat `logs/geoserver.log.*': No such file or
directory
Live-demo mailing list
Live-demo at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/live-demo
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20091016/79e3b720/attachment-0001.html
More information about the Live-demo mailing list
