[Live-demo] Tomcat6 setup for deegree
Cameron Shorter cameron.shorter at lisasoft.com
Wed Sep 2 17:55:53 EDT 2009
Judit,
You raise some good points here.
As per: http://wiki.osgeo.org/wiki/GISVM_Build#Build_Drivers
The GISVM and LiveDVD is targeted at a demo version. The aim is to
highlight the product features, but it not expected to be tuned for high
capacity of complicated scenarios.
Our biggest constraining factor is lack of RAM. So to work around this,
the policy is:
   1. Do not start applications upon power up. (Ie, don't start deamons,
      allow users to start them instead).
   2. Set up examples which, by default, don't depend on other
      applications. Less applications open, means less memory. Ie, Have
      GeoServer access a shapefile instead of PostGIS.
   3. Try to avoid scenarios which write data to disk, as disk space in
      the Live DVD is stored in RAM, and is not cleared afterward.
In your case, I suggest that you install all your applications into the
one tomcat webapp rather than starting another. I'm assuming that having
two web applications in the same webapp will not mean the RAM is
consumed until the application is activated. Is this correct?
If possible, I suggest that you allow the user to turn on Deegree web
apps individually. Ie, create a different desktop icon for Deegree WMS,
Deegree WFS, ...
Judit Mays wrote:
> Hello all,
> I've got a general question about the prefered set-up using the tomcat:
> Do you prefer to have all the deegree war-archives inside
> /var/lib/tomcat6/webapps?
> Or would you prefer to have deegree bring along its own tomcat, instead
> of sharing it with GeoServer or other web applications?
> I've got a bit of a problem. I see that tomcat6 is running with a Java
> heap space of 128MB. This is not enough. I would suggest 512MB for the
> tomcat at least.
> And I don't know if it is such a good idea to add all deegree webapps
> (wms, wfs, wcs, csw, wps, wpvs, iGeoPortal) either. Especially if these
> webapps get started on start up of the system. This will reduce
> performance not only for deegree, but also for any other webapp in
> tomcat6 and maybe even for other desktop applications (depending on the
> memory of the system).
> After all, we are talking about server applications that have specific
> hardware needs. You can't expect every laptop and desktop pc to live up
> to these needs. Are there any hardware specifics that you plan to
> provide with the DVD?
> What I could do is reduce the list of deegree demo services to WFS, WMS,
> WCS (like GeoServer) and the deegree web client iGeoPortal.
> Since WPS and WPVS are working better in deegree3 already, this wouldn't
> be such a bad idea. A demo for those services on LiveDVD would then have
> to wait until deegree3 is stable.
> Any thoughts, ideas or suggestions?
> Kind regards,
> Judit
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
