[Live-demo] gvSIG package
Jorge Gaspar Sanz Salinas jsanz at osgeo.org
Fri Sep 4 03:55:22 EDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi
I've tested the deb package for gvSIG 1.9RC1 (bn1242) on the VM and it
works fine.
The deb package has three caveats:
* It requires from user interaction to accept Sun license for JAI libraries
* The viersion it installs doesn't provide SEXTANTE library, it has to
be installed apart.
* The default language is Spanish so it requires again a first run in
Spanish of gvSIG to set it up in English. When you install gvSIG through
the regular installer you can configure the language but this is not the
case. Changing the language can be scripted, is just changing a value on
a file (/home/user/gvsig/andami-config.xml).
Should I write a simple script to download the deb, install it with its
dependencies and change the default language?
Ingeniero en Geodesia y Cartografía
http://es.osgeo.org
http://wiki.osgeo.org/wiki/Jorge_Sanz
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iQEcBAEBAgAGBQJKoMfqAAoJEAOYD75lvHdBt9kIANQtzbDTNqQ0A1qdiQgSWMZV
WiD44/klD3Yu29QpqPxS6ws/iMjMnENnZKuXkLzL1tYTYZlws1c6ersaChQ0SGLi
/rw5OC98Sh7BE+uwFTpXQ8ugVaGYsd3vKkParsCHg7tQDjOt+qbeyCRUjiug4I2v
Lqxg9kOqdBoUbeH0zsnoEKuZ9DpKm7E2L8B++KIuLAtzzptDp2KwdyFQM9cIwQjq
gzKl4soO8+0B7tPHlAwCLedXPs6lCFXcqQaEdqumdW3BfawLQARh42Wqfejm2P8+
LWBofes92Koduxa0eTU9TLKRQlXHHuGevUrBACnlyKsAuaiYmCsOJwovv0kMhD8=
=OAT9
-----END PGP SIGNATURE-----
More information about the Live-demo mailing list
