[Live-demo] deegree script for installation
Cameron Shorter cameron.shorter at gmail.com
Fri Sep 4 20:54:46 EDT 2009
Thank you Judit,
I've added your scripts to subversion. I hope that you can start using
svn so that you can fix your scripts without going through me. The
process for using svn is at:
http://wiki.osgeo.org/wiki/Live_GIS_Disc#Subversion
I suggest that you add your remaining issues, (currently in your
readme?) into issues in the issue tracker at:
http://trac.osgeo.org/osgeo/query?group=status&component=LiveDVD&order=priority
Then over the next two weeks testing, you can work though and fix the
main outstanding issues.
Judit Mays wrote:
> Hello,
> attached is the deegree installation script and a readme with info on
> testing installation success.
> Actually, creating this install script was a hard job for me, something
> I never did before. My special thanks go to Stefan Hansen and H. Bowman,
> as they provided scripts suitable for copying bits and pieces from.
> Due to time constraints I was not able to change the deegree demo to use
> NC data. Instead, the services run with Utah data.
> Due to "I don't know how..." the "stop deegree" desktop icon doesn't do
> what it should. If anyone can fix it that would be super cool. Otherwise
> please remove the relevant part  creating the stop icon from the install
> script.
> Thanks to all who are making this LiveDVD possible! After creating the
> deegree script I even more appreciate what a great job is being done by
> you all. Cheers!
> Kind regards,
> Judit
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
