[Live-demo] Arramagong GISVM alpha 4 release
Cameron Shorter cameron.shorter at lisasoft.com
Fri Sep 11 05:09:42 EDT 2009
Jorge Gaspar Sanz Salinas wrote:
> Hi,
> I've just downloaded the image and gvSIG is not installed.
> I've run the script and had some problems about the install of the
> sun-java5-jre (it's a dependency of gvsig package), but maybe I should
> explicitly add it to the install script before doing a "dpkg -i" of the
> gvSIG package.
> After installing the java 5 JRE, the gvSIG deb package was configured
> and is working fine, I've loaded some WMS and WFS layers, yes it's not a
> hard testing :-)
> Did you have any problem with the install script?
Jorge, yes, it is a good idea to specifically apt-get java5 if you need
it. (Attempting to install it a second time from a second script won't
cause any problems, it will just be ignored). But that does bring up a
broader question regarding java version, which I'll ask in another email.
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
