[Live-demo] Re: [OSGeo] #438: Postgres 8.3 install script
OSGeo trac_osgeo at osgeo.org
Sun Sep 13 21:20:48 EDT 2009
  Reporter:  darkblueb  |       Owner:  live-demo at lists.osgeo.org
      Type:  defect     |      Status:  new
  Priority:  blocker    |   Component:  LiveDVD
Resolution:             |    Keywords:
Comment (by wildintellect):
 Replying to [comment:2 darkblueb]:
 > cameronshorter fixed the bug with USER=user
 > but now need to set a password/ right after the create user
 > so, put this in a text file anywhere
 > alter role "user" with password 'user'
 > then add to the script  sudo -u postgres pqsl -f /path/to/file
 You shouldn't need to set a password, by default postgres uses ident
 authentication for localhost connections (aka system users). I tested the
 script and it worked for me, but I can see how if the USER variable wasn't
 set right it would cause and issue.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/438#comment:4>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
