[Live-demo] deegree on alpha4
Cameron Shorter cameron.shorter at lisasoft.com
Mon Sep 14 16:52:33 EDT 2009
Judit,
Feel free to change the main.sh script to set the JAVA_HOME variable.
This will set the JAVA_HOME for all the install scripts, but don't think
it will be set outside of the scripts. I'm not sure of an automated way
to set the JAVA_HOME outside of a script life.
Alternatively, please raise a ticket to track the issue.
http://wiki.osgeo.org/wiki/Live_GIS_Disc#Issue_Tracker
Judit Mays wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hello list,
> installation of deegree did not work with alpha4.
> I have identified at least one problem: java-installation path changed
> between this and the former version. My script did not check for the
> Java location but simply assumed it to be the same as before. I will
> change this with the next version of the script.
> It could be helpful for deegree and other Java-dependant software to
> have JAVA_HOME variable set globally.
> Just to make sure I will change the deegree script so it sets JAVA_HOME
> none the less.
> I don't know about alpha5 yet as I can't download it:
> mays at wharariki:~$ wget
> http://download.osgeo.org/livedvd/ArramagongGISVM2009alpha5.7z
> - --2009-09-14 15:07:02--
> Auflösen des Hostnamen »download.osgeo.org«.... 198.202.74.218
> Verbindungsaufbau zu download.osgeo.org|198.202.74.218|:80... verbunden.
> HTTP Anforderung gesendet, warte auf Antwort... 404 Not Found
> 2009-09-14 15:07:03 FEHLER 404: Not Found.
> Kind regards,
> Judit
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iEYEARECAAYFAkquQd4ACgkQ00HMccodrqXK8gCfdMlr5K2GdG6Gop7+4FhMwFD/
> 8T0An11yNI06kjI/xEEz3I4ISmlpdywF
> =7eK1
> -----END PGP SIGNATURE-----
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
