[Live-demo] Re: [OSGeo] #453: R script compiles from source, debs available
Massimo Di Stefano massimodisasha at yahoo.it
Tue Sep 22 10:48:39 EDT 2009
from the page :
http://lib.stat.cmu.edu/R/CRAN/bin/linux/ubuntu/
i've notice the number of packages is limited to :
    r-cran-boot
    r-cran-cluster
    r-cran-codetools
    r-cran-foreign
    r-cran-kernsmooth
    r-cran-lattice
    r-cran-matrix
    r-cran-mgcv
    r-cran-nlme
    r-cran-rpart
    r-cran-survival
    r-cran-vr
    r-cran-rodbc
maybe i'm wrong, not sure,
but if we delete this from the installRpackages script,
can we create confusion, mixing binaries and source compiled packages ?
however,  if the source build is a problem,
why don't build the packages just one time
then create a .tar.gz for the libraries
and upload it on the svn.
So each time the gisvm script well runs it has to download the
prebuild packages instead to re-compile it
(this procedure can works only if we don't run apt-get update /
upgrade on the ubuntu distro. )
make sense for you ?
Thanks,
Massimo.
P.S:
on a fresh ubuntu9.04 machine i activated backports run update/upgrade
and added: :
deb http://<http://cran.ms.unimelb.edu.au/>/bin/linux/ubuntu jaunty/
gpg --keyserver subkeys.pgp.net --recv-key E2A11821
gpg -a --export E2A11821 | sudo apt-key add -
sudo apt-get update
sudo apt-get install r-base r-base-dev
can i try to build the pacjkages and create the :
/usr/lib/R/site-library.tar.gz?
or maybe is better to do this process on the gisVM machine that will
create the iso ?
>  Reporter:  wildintellect  |       Owner:  live-demo at lists.osgeo.org
>      Type:  enhancement    |      Status:  new
>  Priority:  minor          |   Component:  LiveDVD
> Resolution:                 |    Keywords:  R, CRAN
> Comment (by wildintellect):
> Attached file was run on 8.04 more packages may be present in Jaunty
> but
> it's a good start. Who wants to go through and create an apt-get and
> remove them from the installRpackages.r once done.
> Ticket URL: <http://trac.osgeo.org/osgeo/ticket/453#comment:1>
> OSGeo <http://www.osgeo.org/>
> OSGeo committee and general foundation issue
> tracker._______________________________________________
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20090922/fe580acf/attachment.html
More information about the Live-demo mailing list
