[Live-demo] FW: GeoNetwork and LiveDVD
Simon.Pigot at csiro.au Simon.Pigot at csiro.au
Thu Sep 24 05:07:39 EDT 2009
Hi Cameron,
I fixed the startup scripts to remove dependence on being started in /usr/lib/geonetwork/bin earlier in the week. Also I don't really see the need to run with sudo as the installer script changes ownership of everything in /usr/lib/geonetwork to username user, group user - all of this makes me wonder whether wildintellect (Alex?) was running a version which did not contain these changes?
Also I don't understand the changes that have been made to the start_geonetwork and stop_geonetwork.desktop files which now use 'dash launchhelp.sh' in front of the start_geonetwork and stop_geonetwork scripts - I do not have these scripts? I assume launchhelp displays something helpful for the user before launching the start/stop scrips? Can someone point me at these?
I'm building my own copy of the livedvd image now to test this further.
Cheers,
Simon
________________________________________
From: Cameron Shorter [cameron.shorter at gmail.com] On Behalf Of Cameron Shorter [cameron.shorter at lisasoft.com]
Sent: Thursday, 24 September 2009 3:55 PM
To: Pigot, Simon (CMAR, Hobart); live-demo at lists.osgeo.org
Subject: GeoNetwork and LiveDVD
Simon, we plan to start the final build for the LiveDVD tomorrow, Friday
25, and I'm hoping you can help fix the Geonetwork install script
critial error:
http://trac.osgeo.org/osgeo/ticket/455
Geonetwork startup scripts rely on relative paths, the launcher on the
desktop fails to get the user into the correct starting path. Also
requires sudo command which is easy to fix by prepending, the sudo
password:
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
