[Live-demo] FW: GeoNetwork and LiveDVD
Alex Mandel tech_dev at wildintellect.com
Thu Sep 24 09:21:47 EDT 2009
Simon,
Simply put, double clicking on the desktop icon just doesn't work. I
just built beta4 12 hours ago. The hmm, if it still says launchhelp that
might be the problem, it's launchassist which is actually a wrapper to a
sudo command in a file. Happens to be the only way I could get deegree
to launch too. It's not an issue with the command you had, it seems to
be a bug in the way desktop icons execute in xfce.
I'll test some more today, with beta4,
Alex
Simon.Pigot at csiro.au wrote:
> Hi Cameron,
> I fixed the startup scripts to remove dependence on being started in /usr/lib/geonetwork/bin earlier in the week. Also I don't really see the need to run with sudo as the installer script changes ownership of everything in /usr/lib/geonetwork to username user, group user - all of this makes me wonder whether wildintellect (Alex?) was running a version which did not contain these changes?
> Also I don't understand the changes that have been made to the start_geonetwork and stop_geonetwork.desktop files which now use 'dash launchhelp.sh' in front of the start_geonetwork and stop_geonetwork scripts - I do not have these scripts? I assume launchhelp displays something helpful for the user before launching the start/stop scrips? Can someone point me at these?
> I'm building my own copy of the livedvd image now to test this further.
> Cheers,
> Simon
> ________________________________________
> From: Cameron Shorter [cameron.shorter at gmail.com] On Behalf Of Cameron Shorter [cameron.shorter at lisasoft.com]
> Sent: Thursday, 24 September 2009 3:55 PM
> To: Pigot, Simon (CMAR, Hobart); live-demo at lists.osgeo.org
> Subject: GeoNetwork and LiveDVD
> Simon, we plan to start the final build for the LiveDVD tomorrow, Friday
> 25, and I'm hoping you can help fix the Geonetwork install script
> critial error:
> http://trac.osgeo.org/osgeo/ticket/455
> Geonetwork startup scripts rely on relative paths, the launcher on the
> desktop fails to get the user into the correct starting path. Also
> requires sudo command which is easy to fix by prepending, the sudo
> password:
> Cameron Shorter
> Geospatial Systems Architect
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
More information about the Live-demo mailing list
