[Live-demo] [OSGeo] #462: cpuload and terminal to taskbar
OSGeo trac_osgeo at osgeo.org
Sat Sep 26 19:38:57 EDT 2009
Reporter:  hamish   |       Owner:  live-demo at lists.osgeo.org
    Type:  task     |      Status:  new
Priority:  trivial  |   Component:  LiveDVD
Keywords:           |
 no solution yet, but so what has been learned so far isn't for forgotten..
 on the taskbar it would be nice to add a Terminal button next to the
 firefox one, and a cpu load one on the right by the clock.
 if you add them by hand you can make a template, maybe set the cpuload BG
 color to matching grey, then foreground to dark green.
 look in ~/.config/xfce4/panel/launcher-$RAND.rc and cpuload-...rc
 for to copy in. Also we would need to make a before and after diff of the
 panel.xml file then patch it in.
 tricky bit there is that the .config dir prob doesn't exist until the user
 starts XFce for the first time. So some if [ `grep -c cpuload panel.xml`
 -gt 0 ] ; test in .bash_profile ? ... mmmph yuk
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/462>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
