[Live-demo] notes, comments
Gaby Van Wyk gvanwyk at openspatial.com.au
Tue Sep 29 23:55:14 EDT 2009
Hi all
Just installed the live DVD on a Sun Virtual Box from ISO. Everything went smoothly, even the install of the VirtualBox utilities for screen resolution, etc. In general performance seems good and it seems quite workable.
I tested all applications, everything seemed OK on the surface. Apart from similar issues as others have already mentioned, I also have the following comments:
- GeoKettle - username (user) / password (user) does not work. Starting it with 'No Repossitory' works but this is confusing...
- I did NOT have the same font issues reported by others (Assume that is Mac only)
Overall comments
1. It is a pity that we do not have all of the demonstration data in one central place. It would be nice to compare tools using the same data.
2. I feel that for the average person in our target audience the experience will be a little bewildering. We offer a range of icons with no structure to lead the users. I would like to suggest the following (will help set it up if the idea is acceptable and if I have enough time):
2.1. Rename the 'Help' icon to ReadmeFirst. Add an explanation of the structure below at the top of the file.
2.2. Create three folders on the desktop:
	-Desktop GIS
	-Web GIS
	-Statistics
2.3. Move the icons from the desktop to relevant folders, place a readme file in each folder that explains how to get started with each respective application in that section. (We need to provide more than just a write-up of each application - we nee to give them a short step by step just to load and view one or two data layers.
Kind Regards,
Gaby Van Wyk
Solutions Architect
Unit 6, Level 8 South Tower, 1-5 Railway Street Chatswood West NSW 2067 Australia
Main : +61 2 9904 7077
Fax: +61 2 9904 7577
Mobile: +61 4 0653 9607
Your gvanwyk at openspatial.com.au
visit: www.openspatial.com.au
DISCLAIMER : This e-mail must not be copied, disclosed or used by any person other than the addressee(s) named above. Open Spatial Tech. does not endorse or accept responsibility for any personal views expressed in this e-mail.
More information about the Live-demo mailing list
