[Live-demo] Re: [OSGeo] #525: pgrouting data import off
OSGeo trac_osgeo at osgeo.org
Fri Feb 12 04:21:31 EST 2010
  Reporter:  wildintellect  |       Owner:  live-demo at lists.osgeo.org
      Type:  defect         |      Status:  new
  Priority:  major          |   Component:  LiveDVD
Resolution:                 |    Keywords:  pgrouting 3.0RC1
Changes (by wildintellect):
  * keywords:  pgrouting 3.0-alpha4 => pgrouting 3.0RC1
Comment:
 More info on the build error, should forward to pgrouting contact:
 [ 25%] Building C object
 extra/driving_distance/src/CMakeFiles/routing_dd.dir/alpha.o
 /tmp/build_pgrouting/pgrouting/extra/driving_distance/src/alpha.c: In
 function ‘fetch_vertices_columns’:
 /tmp/build_pgrouting/pgrouting/extra/driving_distance/src/alpha.c:137:
 error: ‘INT4OID’ undeclared (first use in this function)
 error: (Each undeclared identifier is reported only once
 error: for each function it appears in.)
 /tmp/build_pgrouting/pgrouting/extra/driving_distance/src/alpha.c:138:
 error: ‘FLOAT8OID’ undeclared (first use in this function)
 make[2]: ***
 [extra/driving_distance/src/CMakeFiles/routing_dd.dir/alpha.o] Error 1
 make[1]: *** [extra/driving_distance/src/CMakeFiles/routing_dd.dir/all]
 Error 2
 make: *** [all] Error 2
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/525#comment:1>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
