[Live-demo] Re: pgRouting build broken
Hamish
hamish_b at yahoo.com
Sun Feb 28 22:05:32 EST 2010
Anton wrote:
> I put my script to trunk, so please check it.
(only the last two comments below are very important)
- "sudo" for apt-get, make install, ldconfig is not needed, the script
already runs with permissions.
- subversion and build-essential are installed by setup.sh, so you can
reasonably expect them to be there already.
- "apt-get install ... libcgal*" IMO it's better to state packages
you want explicitly rather than pulling in by wildcard
- for wget please use options to make it not as noisy. (-nv for tiny
files, --progress=dot:mega for big ones)
- "svn checkout ...pgrouting/trunk" if it absolutely must be from trunk
and not a versioned release, please specify a revision number to checkout
so it will still work in future after their trunk has moved on.
- "FIXME: remove -dev packages once you are done with them. libboost-dev
is hundreds of MB."
regards,
Hamish
More information about the Live-demo
