[Live-demo] arramagong-3.0-alpha1 released
Hamish hamish_b at yahoo.com
Mon Jan 11 11:36:47 EST 2010
Cameron wrote:
> The first of the 3.0 alpha virtual
> machines (and build logs) is now available
> Most applications seemed to install ok, although there are
> some errors in the logs which seem like there are some
> problems.
the first lot went ok, but then it all goes badly wrong. for
one thing the ubuntuGIS sources.list.d hadn't been updated to
use karmic packages..
some notes from looking thru the log file:
java:
jre 5 no longer available
Geoserver:
FIXME: 'export FOO=bar' is a Bashism and will not work with Ubuntu's #!/bin/sh  (which is dash)
gvsig:
needs to use updated packages (libstdc++6, gdal 1.6, java-jre6)
deegree:
checksum error for install_deegree.sh
apache2:
deps?
souces.list.d:
update to use karmic instead of jaunty   (now fixed)
--after this it all pretty much goes to crud presumably due to
the missing package deps.
regards,
Hamish
More information about the Live-demo mailing list
