[Live-demo] [OSGeo] #520: postgis install script triggers "obsolete major version 8.3" message
OSGeo trac_osgeo at osgeo.org
Thu Jan 14 15:24:57 EST 2010
Reporter:  camerons            |       Owner:  live-demo at lists.osgeo.org
    Type:  defect              |      Status:  new
Priority:  normal              |   Component:  LiveDVD
Keywords:  3.0-alpha3 postgis  |
 In building the 3.0-alpha3 version of the liveDVD, I'm getting the
 following query come up (which requires acknowledgement). It comes up in
 the install_postgres.sh script.
 How do you suggest this should be handled? Should we be updating the
 LiveDVD install script for Postgres to a later version?
 Could I tempt you to update the LiveDVD install script?
 https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/bin/install_postgres.sh
 (current version is r2716)
 Issue 1: Should we upgrade to a later version of posgres?
 Issue 2: Please ensure the user is not prompted for a response during the
 build process and we wish this to be automated.
 Package configuration
  â"Oâ"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"¤
 Configuring pos
 tgresql-common
 â"oâ"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"?â"
  â"'
 â"'
  â"' Obsolete major version 8.3
 â┼'
  â"'
 â-®
  â"' The PostgreSQL version 8.3 is obsolete, but the server or client
 â-'
  â"' packages are still installed. Please install the latest packages
 â-'
  â"' (postgresql-8.4 and postgresql-client-8.4) and upgrade the existing
 â-'
  â"' clusters with pg_upgradecluster (see manpage).
 â-'
  â"'
 â-'
  â"' Please be aware that the installation of postgresql-8.4 will
 â-'
  â"' automatically create a default cluster 8.4/main. If you want to
 â-'
  â"' upgrade the 8.3/main cluster, you need to remove the already existing
 â-'
  â"' 8.4 cluster (pg_dropcluster --stop 8.4 main, see manpage for
 â-'
  â"' details).
 â-'
  â"'
 â-'
  â"' The old server and client packages are no longer supported. After the
 â┼"
  â"'
  â"'                                 <Ok>
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/520>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
