[Live-demo] 4.0 rc5 build
Hamish hamish_b at yahoo.com
Sat Jul 31 07:08:30 EDT 2010
Alex:
>> Much better, but still a few quirks:
>> http://download.osgeo.org/livedvd/4.0-rc5/4.0rc5logs.tar.gz
just looking at the 4beta5 logs now, starting with the error list which
collects at the bottom---
- atlasstyler and geopublusher:  failed because their repo was missing.
  [hopefully fixed by r4352]
- Java:  changed to uninstall openjdk-6-jre-headless too (saves 76mb)
- QGIS:  plugins install fails.
    FIXME: use /tmp/build_qgis not /tmp/
    cp: cannot stat `/tmp/.qgis/python/plugins/': No such file or directory
- OSSIM:  ossim.telascience.org was down then, but it's back now.
- pgRouting:
   "Run osm2pgrouting converter (this may take a while)
    host=127.0.0.1 user=user dbname=pgrouting port=5432
    connection failed"
- "Show top 50 packages hogging the most space on the disc:
   94.449 MB        linux-image-2.6.32-24-generic
   92.430 MB        linux-image-2.6.32-21-generic"
   Alex: can you check & remove linux-image-2.6.32-21-generic by hand please?
- fixed end-of-run disk hog/usage stats in svn
  (if above old kernel was a false positive, this will solve that)
>> The Help Launcher is nowhere to be seen,
no idea. backed up to the previous rev which was working.
>> FYI looks like something is still making a /usr/local/livedvd-docs
>> folder but all our stuff is in osgeolive-docs, someone want to find and
>> kill that uneeded folder?
fixed in svn.
>> Firefox homepage reset doesn't work,
should be fixed now.
>> I also added the Geospatial menu from it's file, the cpu monitor and
>> the keyboard switcher so I don't forget to do it on the final builds.
added xkb-plugin to the panel in the skeleton files + user's .config/.
(as mentioned before, can't be logged in as user+xfce for it to stick)
ciao,
Hamish
More information about the Live-demo mailing list
