[Live-demo] logs for osgeo-live-4.0alpha1
Hamish hamish_b at yahoo.com
Sat Jun 5 07:35:32 EDT 2010
Cameron wrote:
> I've had a first crack at building the 4.0 live DVD.
great!
> Only about 1/3 of the applications seem to be working.
> I haven't got to the bottom of why they are not working,
> but I have put the logs online at:
>   http://download.osgeo.org/livedvd/4.0-alpha1/
The following packages have been kept back:
  linux-generic linux-image-generic
--fix by hand?
Package sun-java6-jdk is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
Starting with Lucid, Sun's Java has been moved to the Ubuntu
"Partner" repository,
https://wiki.ubuntu.com/LucidLynx/ReleaseNotes#Sun%20Java%20moved%20to%20the%20Partner%20repository
Sun Java moved to the Partner repository
For Ubuntu 10.04 LTS, the sun-java6 packages have been dropped from the Multiverse section of the Ubuntu archive. It is recommended that you use openjdk-6 instead.
If you can not switch from the proprietary Sun JDK/JRE to OpenJDK, you can install sun-java6 packages from the Canonical Partner Repository. You can configure your system to use this repository via command-line:
     add-apt-repository "deb http://archive.canonical.com/ lucid partner"
It's about time we decided on a Java JRE to use, Sun's or
OpenJDK.
 - software improves with time so abandon old prejudices, base
   new prejudices on new tests.. :)  ie don't assume the new
   version of OpenJDK doesn't work (/as fast), prove it.
 - do we even have license permission to redistribute Sun's?
 - shipping two if we don't have to is wasteful..
ERROR: gvsig package failed to install
--no other error messages exposed? why not?
  why no compliants from ./install_java.sh either?
  ...where has stderr gone? a tee needed?
gvsig-withjre: Depends: libgdal1-1.5.0
--updated in SVN to use lucid's 1.6.0
   (1.7.0 seems avail from UbintuGIS too, if req'd)
... after this pretty much everything else is not at all happy.
I'd suggest running install_java.sh, install_geoserver.sh,
install_gvsig.sh, and install_apache2.sh by hand before trying
another full build. Without java, apache, and gdal installed
properly we aren't going to get very far..
Hamish
More information about the Live-demo mailing list
