[Live-demo] 4a4 first impression
Cameron Shorter cameron.shorter at gmail.com
Tue Jun 22 03:32:45 EDT 2010
On 22/06/10 17:22, Alex Mandel wrote:
> On 06/22/2010 12:02 AM, Brian Hamlin wrote:
>> I downloaded the vdk/omf
>> used virtual box on Debian lenny 64bit amd
>> converted to virtual box format (long operation)
> Virtual Box does not require such a conversion it can use vmdk directly.
What was available was actually a direct export from VirtualBox already.
So yes, you should be able to directly import.
>> running it, with additional RAM (1296M)
>> * opened Postgres PGAdmin
>>    Sydney and Medford dbs both appear to be missing their data
>>    they exist, but only two supporting tables are there.. ??
>> * quick search for all .shp files and all.sql files did not reveal any
>> data for them
> Those data sets are slated to be replaced as soon as we get around to it
> with a generic osm dump (for this year it's barcelona) called something
> like city.osm. Any volunteers?
I'd love someone to work this out asap, because the postgis error logs
are huge, and it seems to really slow down the build process.
>> * can't ssh in
>>    installed ssh meta package, and openssl-server specifically
>>    but, ssh connection is refused.. X or no X
>>    someone may say that this is a good thing
>>    well, if you have a 'user/user' type login, why not enable login?
>>    I booted off a headless server, and wanted to ssh in to the running VM
>>    a better balance could be struck here...
ssh-server should be enabled (I was sshing into the image before I
exported it).
It might be disabled by an import process.
>> more later
>>   -Brian
> There have been some previous posts in regards to this, and discussion
> that you may need to change the port number to something above 1000 for
> it to work.
> Headless(Actuall all forms) Vbox supports Remote Desktop out of the box
> there is no need for ssh, please see virtual box docs for how to do
> this. Also if you add the virtual-box-utils package inside the vm your
> can mount host directories inside the vm and copy/paste between host/client.
> Thanks,
> Alex
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
