[Live-demo] RE: osgeolive 4.0alpha4 available via VNC
Trevor Wekel trevor_wekel at otxsystems.com
Tue Jun 29 17:10:20 EDT 2010
Hi Cameron,
Yes.  Extra docs would be good.  I was not aware of this information.  Looking at some of the other scripts, most icons are still being installed into /usr/share/icons.  However, most of the projects are installing their ".desktop" definitions to /usr/share/applications.
Regards,
Trevor
-----Original Message-----
From: Cameron Shorter [mailto:cameron.shorter at gmail.com]
Sent: June 29, 2010 1:45 PM
To: Trevor Wekel; live-demo at lists.osgeo.org; Hamish
Subject: Re: osgeolive 4.0alpha4 available via VNC
Trevor,
the icons moved into folders in the install_desktop.sh script.
You will need to update this script at some point.
Hamish set this up and may add some extra tips on what is required.
Trevor,
Have you been able to work out why the mapguide .deb files are installed
into the ~/gisvm/bin directory instead of /tmp/build_mapguide/ directory?
On 30/06/10 01:42, Trevor Wekel wrote:
> Hi Cameron,
> I gave MapGuide a quick check.  Everything seems to be working in 4.0alpha4.  I have one quick question on the menu system.  I have the MapGuide desktop icons registered as "Categories=Application;Geography".  Is that good enough to get registered in the menu system somewhere?
> Thanks,
> Trevor
> Sent: June 28, 2010 7:43 AM
> To: Bastian Schäffer; Stefan Krüger; Judit Mays; Thierry Badard; pieter.degraef at geosparc.com; Hamish; Jorge Gaspar Sanz Salinas; Sergio Baños Calvo; Howard Butler; Astrid Emde; Eric Lemoine; Cédric Moullet; Trevor Wekel; Dane Springmeyer; Alan Boudreault; klokan at gmail.com; Stefan Steiniger; Alex Mandel; Pirmin Kalberer; Massimo Di Stefano; Anton Patrushev; Jody Garnett; andrea antonello; Juan Lucas Domínguez Rubio
> Subject: osgeolive 4.0alpha4 available via VNC
> OSGeoLive project champions:
> You can VNC into the 4.0alpha4 version of the OSGeoLive DVD now.
> You will need a VNC client, like tight VNC.
> Log into camilla-vm.lisasoft.com:1
> password=osgeo1
> Feel free to try your application, and update and run your build scripts.
> Note that others may be logging in at the same time as you, so you may
> find someone else moving the mouse.
> If this happens, I suggest logging into irc://freenode.net#osgeo and
> coordinating with the other person, or come back later.
> I'm just finishing off the next release 4.0alpha5, which seems to have a
> number of errors preventing a number of applications from working (also
> preventing me from installing vnc4server).
> Logs at: http://download.osgeo.org/livedvd/4.0-alpha5/
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
