[Live-demo] sample OSM data for Gosmore
Dane Springmeyer blake at hailmail.net
Wed Mar 3 14:19:32 EST 2010
On Mar 3, 2010, at 2:29 AM, Hamish wrote:
> Thanks Dane, all,
>> Yes this is a very good idea. Having a sample .osm file
>> around will benefit many applications. In addition to the
>> ones you note QGIS and Mapnik can also render .osm
>> directly.
>> Makes sense to meet to grab Barcelona, which can be as easy as:
>> $ wget -O barcelona.osm http://osmxapi.hypercube.telascience.org/api/0.6/map?bbox=1.998653,41.307213,2.343693,41.495207
>> Downloading from the osmxapi takes about 6 minutes and is
>> around 20MB. I've reposted here:
>> http://dbsgeo.com/tmp/barcelona.osm
>> ... so you can access quicker.
> thanks. I have now added that file (.bzip2'd) to
>   http://download.osgeo.org/livedvd/data/
> (see READMEs there for comments)
> and modified the OSM install script to add it to the disc.
> We should (in some months time) -at the last moment redownload that
> file
> so it includes all of the latest OSM edits.
Yes, certainly, and if time/energy permits touch it up a bit. For
example we may want to clip some of the long dangling lines that
extend out from barcelona...
>> We should also push the .osm file into postgis/postgres with
>> osm2pgsql.
>> $ createdb -T template_postgis osm_barcelona
>> $ osm2pgsql -d osm_barcelona barcelona.osm
> after thinking about it I think it might be better to just include the
> raw .osm file on the disc (ie a basic starting point if you don't have
> a network connection), and list the above commands in the tutorials
> in order to demonstrate/teach the workflow.
Certainly makes sense. Do you know, do we have osm2pgsql installed?
This gets and whether I should set up the osm.xml + osm2pgsql stack
too, although I don't have the spare time at the moment, but would be
good before FOSS4G...
Dane
More information about the Live-demo mailing list
