[Live-demo] Link checking results
Cameron Shorter cameron.shorter at gmail.com
Sun Mar 14 20:19:41 EDT 2010
I've run link checks against the LiveDVD docs.
Below are the results.
I've fixed a couple of the issues already, and some of the other issues
are false positives (pointing at web services which have not been
started or similar).
I expect to continue working through these issues in 9 hours or so, if
someone doesn't get to it first.
LinkChecker 5.1              Copyright (C) 2000-2009 Bastian Kleineidam
LinkChecker comes with ABSOLUTELY NO WARRANTY!
This is free software, and you are welcome to redistribute it
under certain conditions. Look at the file `LICENSE' within this
distribution.
Get the newest version at http://linkchecker.sourceforge.net/
Write comments and bugs to calvin at users.sourceforge.net
Start checking at 2010-03-13 02:45:53-007
ID         5
URL        `./WindowsInstallers/'
Name       `WindowsInstallers'
Parent URL file:///usr/local/share/livedvd-docs/index.html, line 47, col 46
Real URL   file:///usr/local/share/livedvd-docs/WindowsInstallers/
Check Time 0.000 seconds
Warning    Base URL is not properly normed. Normed URL is
           WindowsInstallers/.
Result     Error: URLError: <urlopen error [Errno 2] No such file or
directory: '/usr/local/share/livedvd-docs/WindowsInstallers/'>
Cameron's note: Fixed by providing a symbolic link
ID         6
URL        `./MacInstallers/'
Name       `MacInstallers'
Parent URL file:///usr/local/share/livedvd-docs/index.html, line 48, col 5
Real URL   file:///usr/local/share/livedvd-docs/MacInstallers/
           MacInstallers/.
directory: '/usr/local/share/livedvd-docs/MacInstallers/'>
ID         62
URL        `www.osgeo.org/sponsors/autodesk'
Parent URL file:///usr/local/share/livedvd-docs/sponsors.html, line 53,
col 7
Real URL
file:///usr/local/share/livedvd-docs/www.osgeo.org/sponsors/autodesk
directory: '/usr/local/share/livedvd-docs/www.osgeo.org/sponsors/autodesk'>
10 URLs active,   141 URLs queued,   81 URLs checked, runtime 5 seconds
10 URLs active,   154 URLs queued,  109 URLs checked, runtime 10 seconds
10 URLs active,   154 URLs queued,  109 URLs checked, runtime 15 seconds
10 URLs active,   154 URLs queued,  109 URLs checked, runtime 20 seconds
10 URLs active,   154 URLs queued,  109 URLs checked, runtime 25 seconds
10 URLs active,   147 URLs queued,  116 URLs checked, runtime 30 seconds
10 URLs active,   138 URLs queued,  125 URLs checked, runtime 35 seconds
ID         172
URL        `http://www.gvsig.gva.es/eng/gvsig-mobile'
Name       `original version'
Parent URL file:///usr/local/share/livedvd-docs/content.html, line 43, col 9
Real URL   http://www.gvsig.gva.es/eng/gvsig-mobile
Check Time 30.410 seconds
Warning    Access denied by robots.txt, checked only syntax.
Result     Valid: syntax OK
10 URLs active,   276 URLs queued,  322 URLs checked, runtime 40 seconds
10 URLs active,   274 URLs queued,  345 URLs checked, runtime 45 seconds
ID         348
URL        `/favicon.ico'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 7, col 3
Real URL   file:///favicon.ico
directory: '/favicon.ico'>
ID         349
URL        `/opensearch_desc.php'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 8, col 3
Real URL   file:///opensearch_desc.php
directory: '/opensearch_desc.php'>
ID         350
URL        `/index.php?title=Live_GIS_Disc_Testing&action=creativecommons'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 9, col 3
Real URL
file:///index.php?title=Live_GIS_Disc_Testing&action=creativecommons
directory: '/index.php?title=Live_GIS_Disc_Testing&action=creativecommons'>
ID         351
URL        `http://www.openjump.org/'
Name       `OpenJUMP 1.3'
Parent URL file:///usr/local/share/livedvd-docs/content.html, line 94, col 5
Real URL   http://www.openjump.org/
Check Time 11.113 seconds
Result     Error: error: [Errno 104] Connection reset by peer
10 URLs active,   267 URLs queued,  352 URLs checked, runtime 50 seconds
ID         354
URL        `/skins/common/commonPrint.css?164'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 18, col 3
Real URL   file:///skins/common/commonPrint.css?164
directory: '/skins/common/commonPrint.css?164'>
ID         355
URL        `/skins/common/wikibits.js?164'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 56, col 3
Real URL   file:///skins/common/wikibits.js?164
directory: '/skins/common/wikibits.js?164'>
ID         356
URL        `/index.php?title=-&action=raw&gen=js&useskin=monobook'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 57, col 3
Real URL   file:///index.php?title=-&action=raw&gen=js&useskin=monobook
directory: '/index.php?title=-&action=raw&gen=js&useskin=monobook'>
ID         357
URL        `/skins/common/ajax.js?164'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 64, col 3
Real URL   file:///skins/common/ajax.js?164
directory: '/skins/common/ajax.js?164'>
ID         358
URL
`/index.php?title=Special:ExportRDF/Live_GIS_Disc_Testing&xmlmime=rdf'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 68, col 5
Real URL
file:///index.php?title=Special:ExportRDF%2FLive_GIS_Disc_Testing&xmlmime=rdf
Check Time 0.001 seconds
Warning    Base URL is not properly normed. Normed URL is /index.
           lmime=rdf.
directory:
'/index.php?title=Special:ExportRDF/Live_GIS_Disc_Testing&xmlmime=rdf'>
ID         359
URL        `/wiki/Live_GIS_Disc'
Name       `Live GIS Disc'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 81, col 76
Real URL   file:///wiki/Live_GIS_Disc
directory: '/wiki/Live_GIS_Disc'>
ID         364
URL
`http://localhost:3420/geomajas-tutorial/applications/tutorial/html/'
Name
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 180, col 52
Real URL
Check Time 3.795 seconds
Result     Error: error: [Errno 111] Connection refused
ID         365
URL        `http://localhost:8081/'
Name       `http://localhost:8081/'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 213, col 52
Real URL   http://localhost:8081/
Check Time 1.829 seconds
10 URLs active,   253 URLs queued,  366 URLs checked, runtime 55 seconds
ID         371
URL        `/wiki/Special:Categories'
Name       `Special:Categories'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 713, col 88
Real URL   file:///wiki/Special%3ACategories
           /wiki/Special%3ACategories.
directory: '/wiki/Special:Categories'>
ID         372
URL        `/wiki/Category:Live-demo'
Name       `Category:Live-demo'
col 184
Real URL   file:///wiki/Category%3ALive-demo
           /wiki/Category%3ALive-demo.
directory: '/wiki/Category:Live-demo'>
ID         373
URL        `/wiki/Live_GIS_Disc_Testing'
Name       `View the content page [c]'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 723, col 47
Real URL   file:///wiki/Live_GIS_Disc_Testing
directory: '/wiki/Live_GIS_Disc_Testing'>
ID         374
URL        `/wiki/Talk:Live_GIS_Disc_Testing'
Name       `Discussion about the content page [t]'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 724, col 24
Real URL   file:///wiki/Talk%3ALive_GIS_Disc_Testing
           /wiki/Talk%3ALive_GIS_Disc_Testing.
directory: '/wiki/Talk:Live_GIS_Disc_Testing'>
ID         375
URL        `/index.php?title=Live_GIS_Disc_Testing&action=edit'
Name       `This page is protected.\nYou can view its source. [e]'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 725, col 30
Real URL   file:///index.php?title=Live_GIS_Disc_Testing&action=edit
directory: '/index.php?title=Live_GIS_Disc_Testing&action=edit'>
ID         376
URL        `/index.php?title=Live_GIS_Disc_Testing&action=history'
Name       `Past versions of this page. [h]'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 726, col 27
Real URL   file:///index.php?title=Live_GIS_Disc_Testing&action=history
directory: '/index.php?title=Live_GIS_Disc_Testing&action=history'>
ID         377
URL
`/index.php?title=Special:UserLogin&returnto=Live_GIS_Disc_Testing'
Name       `You are encouraged to log in, it is not mandatory however. [o]'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 734, col 23
Real URL
file:///index.php?title=Special:UserLogin&returnto=Live_GIS_Disc_Testing
directory:
'/index.php?title=Special:UserLogin&returnto=Live_GIS_Disc_Testing'>
ID         378
URL        `/skins/common/images/osgeo2.png'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 739, col 3
Real URL   file:///skins/common/images/osgeo2.png
directory: '/skins/common/images/osgeo2.png'>
ID         380
URL        `/wiki/Main_Page'
Name       `Main Page'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 746, col 37
Real URL   file:///wiki/Main_Page
directory: '/wiki/Main_Page'>
ID         381
URL        `/wiki/OSGeo_Wiki:Community_Portal'
Name       `About the project, what you can do, where to find things'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 747, col 23
Real URL   file:///wiki/OSGeo_Wiki%3ACommunity_Portal
           /wiki/OSGeo_Wiki%3ACommunity_Portal.
directory: '/wiki/OSGeo_Wiki:Community_Portal'>
ID         382
URL        `/wiki/OSGeo_Wiki:Current_events'
Name       `Find background information on current events'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 748, col 30
Real URL   file:///wiki/OSGeo_Wiki%3ACurrent_events
           /wiki/OSGeo_Wiki%3ACurrent_events.
directory: '/wiki/OSGeo_Wiki:Current_events'>
ID         383
URL        `/wiki/Special:RecentChanges'
Name       `The list of recent changes in the wiki. [r]'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 749, col 30
Real URL   file:///wiki/Special%3ARecentChanges
           /wiki/Special%3ARecentChanges.
directory: '/wiki/Special:RecentChanges'>
ID         384
URL        `/wiki/Special:Random'
Name       `Load a random page [x]'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 750, col 27
Real URL   file:///wiki/Special%3ARandom
           /wiki/Special%3ARandom.
directory: '/wiki/Special:Random'>
ID         385
URL        `/wiki/Help:Contents'
Name       `The place to find out.'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 751, col 21
Real URL   file:///wiki/Help%3AContents
           /wiki/Help%3AContents.
directory: '/wiki/Help:Contents'>
ID         386
URL        `/wiki/Special:Search'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 758, col 4
Real URL   file:///wiki/Special%3ASearch
           /wiki/Special%3ASearch.
directory: '/wiki/Special:Search'>
ID         387
URL        `/wiki/Special:WhatLinksHere/Live_GIS_Disc_Testing'
Name       `List of all wiki pages that link here [j]'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 769, col 30
Real URL   file:///wiki/Special%3AWhatLinksHere/Live_GIS_Disc_Testing
           /wiki/Special%3AWhatLinksHere/Live_GIS_Disc_Testing.
directory: '/wiki/Special:WhatLinksHere/Live_GIS_Disc_Testing'>
ID         388
URL        `/wiki/Special:RecentChangesLinked/Live_GIS_Disc_Testing'
Name       `Recent changes in pages linked from this page [k]'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 770, col 36
Real URL   file:///wiki/Special%3ARecentChangesLinked/Live_GIS_Disc_Testing
Warning    Base URL is not properly normed. Normed URL is /wiki/S
           pecial%3ARecentChangesLinked/Live_GIS_Disc_Testing.
directory: '/wiki/Special:RecentChangesLinked/Live_GIS_Disc_Testing'>
ID         389
URL        `/wiki/Special:Upload'
Name       `Upload files [u]'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 771, col 19
Real URL   file:///wiki/Special%3AUpload
           /wiki/Special%3AUpload.
directory: '/wiki/Special:Upload'>
ID         390
URL        `/wiki/Special:SpecialPages'
Name       `List of all special pages [q]'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 772, col 25
Real URL   file:///wiki/Special%3ASpecialPages
           /wiki/Special%3ASpecialPages.
directory: '/wiki/Special:SpecialPages'>
ID         391
URL        `/index.php?title=Live_GIS_Disc_Testing&printable=yes'
Name       `Printable version of this page [p]'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 773, col 22
Real URL   file:///index.php?title=Live_GIS_Disc_Testing&printable=yes
directory: '/index.php?title=Live_GIS_Disc_Testing&printable=yes'>
ID         392
URL        `/index.php?title=Live_GIS_Disc_Testing&oldid=46053'
Name       `Permanent link to this version of the page'
col 197
Real URL   file:///index.php?title=Live_GIS_Disc_Testing&oldid=46053
directory: '/index.php?title=Live_GIS_Disc_Testing&oldid=46053'>
ID         393
URL
`http://opencpn.cvs.sourceforge.net/viewvc/*checkout*/opencpn/opencpn/data/doc/tips.html#Getting_Started'
Name
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 545, col 31
Real URL
Check Time 1.732 seconds
ID         394
URL        `/skins/common/images/poweredby_mediawiki_88x31.png'
Name       `Powered by MediaWiki'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 779, col 66
Real URL   file:///skins/common/images/poweredby_mediawiki_88x31.png
directory: '/skins/common/images/poweredby_mediawiki_88x31.png'>
ID         396
URL        `/skins/common/images/somerights20.png'
Name       `Creative Commons Legal Code'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 780, col 96
Real URL   file:///skins/common/images/somerights20.png
directory: '/skins/common/images/somerights20.png'>
ID         397
URL        `/wiki/OSGeo_Wiki:Privacy_policy'
Name       `OSGeo Wiki:Privacy policy'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 785, col 22
Real URL   file:///wiki/OSGeo_Wiki%3APrivacy_policy
           /wiki/OSGeo_Wiki%3APrivacy_policy.
directory: '/wiki/OSGeo_Wiki:Privacy_policy'>
ID         398
URL        `/wiki/OSGeo_Wiki:About'
Name       `OSGeo Wiki:About'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 786, col 20
Real URL   file:///wiki/OSGeo_Wiki%3AAbout
           /wiki/OSGeo_Wiki%3AAbout.
directory: '/wiki/OSGeo_Wiki:About'>
ID         399
URL        `/wiki/OSGeo_Wiki:General_disclaimer'
Name       `OSGeo Wiki:General disclaimer'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 787, col 25
Real URL   file:///wiki/OSGeo_Wiki%3AGeneral_disclaimer
           /wiki/OSGeo_Wiki%3AGeneral_disclaimer.
directory: '/wiki/OSGeo_Wiki:General_disclaimer'>
ID         401
URL        `/wiki/Special:Categories' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 874, col 88
ID         402
URL        `/wiki/Category:Live-demo' (cached)
col 184
ID         403
URL        `/wiki/Live_GIS_Disc_Testing' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 884, col 47
ID         404
URL        `/wiki/Talk:Live_GIS_Disc_Testing' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 885, col 24
ID         405
URL        `/index.php?title=Live_GIS_Disc_Testing&action=edit' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 886, col 30
ID         406
URL        `/index.php?title=Live_GIS_Disc_Testing&action=history' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 887, col 27
ID         407
URL
`/index.php?title=Special:UserLogin&returnto=Live_GIS_Disc_Testing' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 895, col 23
Real URL
directory:
ID         408
URL        `/skins/common/images/osgeo2.png' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 900, col 3
ID         409
URL        `/wiki/Main_Page' (cached)
Name       `Main Page'
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 907, col 37
ID         410
URL        `/wiki/OSGeo_Wiki:Community_Portal' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 908, col 23
ID         411
URL        `/wiki/OSGeo_Wiki:Current_events' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 909, col 30
ID         412
URL        `/wiki/Special:RecentChanges' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 910, col 30
ID         413
URL        `/wiki/Special:Random' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 911, col 27
ID         414
URL        `/wiki/Help:Contents' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 912, col 21
ID         415
URL        `/wiki/Special:Search' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 919, col 4
ID         416
URL        `/wiki/Special:WhatLinksHere/Live_GIS_Disc_Testing' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 930, col 30
ID         417
(cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 931, col 36
ID         418
URL        `/wiki/Special:Upload' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 932, col 19
ID         419
URL        `/wiki/Special:SpecialPages' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 933, col 25
ID         420
URL        `/index.php?title=Live_GIS_Disc_Testing&printable=yes' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 934, col 22
ID         421
URL        `/index.php?title=Live_GIS_Disc_Testing&oldid=46144'
col 197
Real URL   file:///index.php?title=Live_GIS_Disc_Testing&oldid=46144
directory: '/index.php?title=Live_GIS_Disc_Testing&oldid=46144'>
ID         422
URL        `/skins/common/images/poweredby_mediawiki_88x31.png' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 940, col 66
ID         424
URL        `/skins/common/images/somerights20.png' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 941, col 96
ID         425
URL        `/wiki/OSGeo_Wiki:Privacy_policy' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 946, col 22
ID         426
URL        `/wiki/OSGeo_Wiki:About' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 947, col 20
ID         427
URL        `/wiki/OSGeo_Wiki:General_disclaimer' (cached)
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 948, col 25
10 URLs active,   176 URLs queued,  443 URLs checked, runtime 1 minute,
0 seconds
ID         446
URL
`http://lucasdom.homelinux.org/cgi-bin/mapserv.exe?map=D:/MAPSERVERCARTO/MAPFILES/wms005.map&REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&LAYERS=world_countries,poi&SRS=EPSG:900913&BBOX=-10000000,-10000000,10000000,10000000&WIDTH=500&HEIGHT=500&FORMAT=image/png&STYLES=default,default&TRANSPARENT=TRUE'
Name
Parent URL file:///usr/local/share/livedvd-docs/tests.html, line 666, col 14
Real URL
http://lucasdom.homelinux.org/cgi-bin/mapserv.exe?map=D:%2FMAPSERVERCARTO%2FMAPFILES%2Fwms005.map&REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&LAYERS=world_countries,poi&SRS=EPSG:900913&BBOX=-10000000,-10000000,10000000,10000000&WIDTH=500&HEIGHT=500&FORMAT=image%2Fpng&STYLES=default,default&TRANSPARENT=TRUE
Check Time 6.351 seconds
D/L Time   2.498 seconds
Size       18.36KB
           S=default,default&TRANSPARENT=TRUE.
Result     Valid: 200 OK
ID         448
URL        `http://gvsig.org/'
Name       `gvSIG'
Parent URL
file:///usr/local/share/livedvd-docs/doc/gvsig_description.html, line
110, col 7
Real URL   http://gvsig.org/
Check Time 5.718 seconds
10 URLs active,   170 URLs queued,  449 URLs checked, runtime 1 minute,
5 seconds
ID         454
URL        `http://www.gvsig.gva.es/'
Name       `http://www.gvsig.gva.es/'
Parent URL
file:///usr/local/share/livedvd-docs/doc/ugvsigmobile_description.html,
line 127, col 214
Check Time 7.527 seconds
ID         456
URL        `/usr/local/share/udig/udig-data'
Name       `udig-data'
Parent URL
file:///usr/local/share/livedvd-docs/doc/udig_description.html, line
110, col 98
Real URL   file:///usr/local/share/udig/udig-data/
D/L Time   0.001 seconds
Size       65B
Warning    Added trailing slash to directory.
Result     Valid: directory
ID         457
URL        `/usr/local/share/udig/udig-docs/uDigWalkthrough2.pdf'
Name       `uDig Walkthrough2'
Parent URL
116, col 98
Real URL   file:///usr/local/share/udig/udig-docs/uDigWalkthrough2.pdf
directory: '/usr/local/share/udig/udig-docs/uDigWalkthrough2.pdf'>
ID         459
URL        `http://localhost:8880/geonetwork'
Name       `http://localhost:8880/geonetwork'
Parent URL
file:///usr/local/share/livedvd-docs/doc/geonetwork_description.html,
line 118, col 238
Real URL   http://localhost:8880/geonetwork
Check Time 6.618 seconds
10 URLs active,   160 URLs queued,  459 URLs checked, runtime 1 minute,
10 seconds
10 URLs active,   155 URLs queued,  464 URLs checked, runtime 1 minute,
15 seconds
ID         465
URL        `http://forge.osor.eu/plugins/wiki/index.php?id=13%26type=g'
Name       `Sextante 0.3'
Parent URL
file:///usr/local/share/livedvd-docs/doc/kosmo_description.html, line
127, col 96
Real URL   http://forge.osor.eu/plugins/wiki/index.php?id=13%26type%3Dg
Check Time 9.385 seconds
D/L Time   0.830 seconds
Size       15.72KB
Warning    Base URL is not properly normed. Normed URL is http://
           forge.osor.eu/plugins/wiki/index.php?id=13%26type%3Dg.
10 URLs active,   149 URLs queued,  470 URLs checked, runtime 1 minute,
20 seconds
10 URLs active,   143 URLs queued,  476 URLs checked, runtime 1 minute,
25 seconds
10 URLs active,   130 URLs queued,  489 URLs checked, runtime 1 minute,
30 seconds
10 URLs active,   122 URLs queued,  497 URLs checked, runtime 1 minute,
35 seconds
ID         500
URL        `http://www.dnr.state.mn.us/maps/compass.html'
Name       `Recreation Compass'
Parent URL
file:///usr/local/share/livedvd-docs/doc/mapserver_description.html,
line 94, col 293
Real URL   http://www.dnr.state.mn.us/maps/compass.html
Check Time 6.781 seconds
ID         507
URL
`http://showmedo.com/videotutorials/video?name=1800050%26fromSeriesID=180'
Name
`http://showmedo.com/videotutorials/video?name=1800050&fromSeriesID=180'
Parent URL
file:///usr/local/share/livedvd-docs/doc/osm_description.html, line 119,
col 278
Real URL
http://showmedo.com/videotutorials/video?name=1800050%26fromSeriesID%3D180
Check Time 11.216 seconds
D/L Time   0.430 seconds
Size       93B
Info       Redirected to `http://showmedo.com/'.
           The redirected URL is outside of the domain filter,
           eriesID%3D180.
Result     Valid: filtered
10 URLs active,   112 URLs queued,  507 URLs checked, runtime 1 minute,
40 seconds
ID         510
URL        `http://grass.osgeo.org/gdp/grassmanuals/grass64_module_list.pdf'
Name       `synopsis of the GRASS modules'
Parent URL
file:///usr/local/share/livedvd-docs/doc/grass_description.html, line
152, col 59
Real URL   http://grass.osgeo.org/gdp/grassmanuals/grass64_module_list.pdf
Check Time 3.694 seconds
ID         511
URL        `file:///usr/local/share/qgis/qgis-1.1.0_user_guide_en.pdf'
Name       `QGIS Manual'
Parent URL
file:///usr/local/share/livedvd-docs/doc/qgis_description.html, line
118, col 350
Real URL   file:///usr/local/share/qgis/qgis-1.1.0_user_guide_en.pdf
directory: '/usr/local/share/qgis/qgis-1.1.0_user_guide_en.pdf'>
ID         512
URL
`http://grass.osgeo.org/gdp/grassmanuals/grass64_module_list.html'
Name       `HTML version'
Parent URL
152, col 198
Real URL   http://grass.osgeo.org/gdp/grassmanuals/grass64_module_list.html
Check Time 3.401 seconds
ID         513
(cached)
Name       `QGIS Manual'
Parent URL
122, col 105
10 URLs active,   102 URLs queued,  517 URLs checked, runtime 1 minute,
45 seconds
10 URLs active,    95 URLs queued,  524 URLs checked, runtime 1 minute,
50 seconds
/usr/lib/python2.6/dist-packages/linkcheck/httplib2.py:1205:
DeprecationWarning: socket.ssl() is deprecated.  Use ssl.wrap_socket()
instead.
  ssl = socket.ssl(sock, self.key_file, self.cert_file)
10 URLs active,    87 URLs queued,  532 URLs checked, runtime 1 minute,
55 seconds
ID         533
URL        `http://localhost:8000/'
Name       `TileLite Welcome Page'
Parent URL
file:///usr/local/share/livedvd-docs/doc/mapnik_description.html, line
113, col 176
Real URL   http://localhost:8000/
Check Time 2.977 seconds
ID         534
URL        `/usr/local/share/mapnik/demo'
Name       `example "population.xml" mapfile.'
Parent URL
120, col 387
Real URL   file:///usr/local/share/mapnik/demo/
Check Time 0.006 seconds
D/L Time   0.002 seconds
Size       295B
ID         537
URL
`http://svn.mapnik.org/trunk/docs/api_docs/python/mapnik-module.html#Datasource'
Name       `datasource plugins'
Parent URL
104, col 1870
Real URL
Check Time 5.165 seconds
Result     Error: 404 Not Found
10 URLs active,    72 URLs queued,  547 URLs checked, runtime 2 minutes,
0 seconds
ID         561
URL        `http://octave.sourceforge.net/doc/funref_mapping.html'
Name       `function reference'
Parent URL
file:///usr/local/share/livedvd-docs/doc/octave_description.html, line
121, col 181
Real URL   http://octave.sourceforge.net/doc/funref_mapping.html
Check Time 2.881 seconds
10 URLs active,    45 URLs queued,  574 URLs checked, runtime 2 minutes,
5 seconds
ID         578
URL        `doc/gmt_description.html'
Name       `GMT'
Parent URL
file:///usr/local/share/livedvd-docs/doc/mb-system_description.html,
line 103, col 212
Real URL   file:///usr/local/share/livedvd-docs/doc/doc/gmt_description.html
directory: '/usr/local/share/livedvd-docs/doc/doc/gmt_description.html'>
10 URLs active,    40 URLs queued,  579 URLs checked, runtime 2 minutes,
10 seconds
16 seconds
21 seconds
ID         580
URL        `mailto:info%40refractions.net'
Name       `Ask us'
Parent URL
file:///usr/local/share/livedvd-docs/doc/postgis_description.html, line
106, col 702
Real URL   mailto:info at refractions.net
Check Time 60.420 seconds
           mailto:info at refractions.net.
Result     Error: timeout: timed out
10 URLs active,    39 URLs queued,  580 URLs checked, runtime 2 minutes,
26 seconds
31 seconds
36 seconds
41 seconds
46 seconds
ID         581
URL        `http://%20en.geopublishing.org/features'
Name       `available online'
Parent URL
file:///usr/local/share/livedvd-docs/doc/geopublishing_description.html,
line 125, col 29
Real URL   http://%20en.geopublishing.org/features
Check Time 44.652 seconds
Result     Error: gaierror: [Errno -2] Name or service not known
ID         595
URL        `http://localhost:5000/'
Name       `http://localhost:5000'
Parent URL
file:///usr/local/share/livedvd-docs/doc/mapfish_description.html, line
108, col 213
Real URL   http://localhost:5000/
Check Time 1.046 seconds
ID         596
URL        `http://localhost:5001/'
Name       `http://localhost:5001'
Parent URL
130, col 75
Real URL   http://localhost:5001/
Check Time 0.855 seconds
ID         609
URL        `http://localhost:8000/' (cached)
Name       `http://localhost:8000'
Parent URL
113, col 383
ID         610
Name       `http://localhost:8000.'
Parent URL
114, col 409
ID         618
URL        `http://localhost:5000/' (cached)
Parent URL
130, col 12
 9 URLs active,     2 URLs queued,  618 URLs checked, runtime 2 minutes,
51 seconds
ID         622
URL        `http://www.R-project.org/COPYING'
Name       `GNU General Public License'
Parent URL file:///usr/local/share/livedvd-docs/doc/R_description.html,
line 113, col 123
Real URL   http://www.r-project.org/COPYING
Check Time 1.757 seconds
Info       Last modified Fri, 21 Apr 2006 15:12:24 GMT.
           http://www.r-project.org/COPYING.
That's it. 629 links checked. 49 warnings found (3 ignored or duplicates
not printed). 82 errors found.
Stopped checking at 2010-03-13 02:48:53-007 (2 minutes, 59 seconds)
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
