[Live-demo] [OSGeo] #645: Marble crash when cancelling layer generation
OSGeo trac_osgeo at osgeo.org
Wed Oct 20 07:47:54 EDT 2010
 Reporter:  activityworkshop  |       Owner:  live-demo@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:
Component:  LiveDVD           |    Keywords:  marble, crash
 When running marble, if you select a layer for the first time (eg
 satellite view) then a progress bar pops up saying that it may take some
 time to generate the layer.  If you press the cancel button, then marble
 crashes with a "Floating Point Exception".
 If the system is running well then this dialog disappears again quickly so
 you have to be quick to reproduce this error.  But if the disk takes time
 to spin up or it's a bit slow for some other reason then it's tempting to
 press cancel.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/645>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
