[Live-demo] OSGeo Live Ticket 742
Frank Gasdorf fgdrf at users.sourceforge.net
Fri Aug 5 16:40:19 EDT 2011
Alex,
I guess you are the man for VM setup, aren't you? Could you please have a
look at the ticket mentioned below (742) I've no idea what happened between
the alpha and beta release builds for the VM.
It seems to me that the firefox installation has not completed successfully.
Do you have any ideas?
Thanks a lot,
Frank
---------- Forwarded message ----------
From: Frank Gasdorf <fgdrf at users.sourceforge.net>
Date: 2011/8/2
Subject: Re: Calling for OSGeo-Live Testers
To: Cameron Shorter <cameron.shorter at gmail.com>, live-demo at lists.osgeo.org
few minutes ago I added myself to the list (udig) and added "Natural Earth"
to column "Uses common dataset?".
If successfully done I guess I should change the filed -color from yellow to
green (QuickStart status), shouldn't I?
But with the beta1 build I had some trouble with the Firefox installation.
Alex, could you check ticket https://trac.osgeo.org/osgeo/ticket/742 I believe
something changed between alpha and beta builds ...
Started beta3 download and will try it later...
Cheers, Frank
2011/8/2 Cameron Shorter <cameron.shorter at gmail.com>
> Frank,
> I wonder whether you will be able to help with the UAT?
> Do you have enough bandwidth to download a VM?
> -------- Original Message --------  Subject: Calling for OSGeo-Live
> Testers  Date: Tue, 02 Aug 2011 21:15:26 +1000  From: Cameron Shorter
> <cameron.shorter at gmail.com> <cameron.shorter at gmail.com>  To:
> live-demo at lists.osgeo.org <live-demo at lists.osgeo.org><live-demo at lists.osgeo.org>
> Apart from a couple of exceptions, I believe we have the final versions
> of all 49 osgeo-live applications installed on OSGeo-Live, and for the
> next 2 weeks, we will be in the User Acceptance Test phase of OSGeo-Live.
> What we are looking for is a number of testers who can download the
> latest Virtual Machine from http://live.osgeo.org/dev/build/ then
> support projects by testing applications and making sure they work.
> Once tested, please update the "Tested By" column in our status sheet: https://spreadsheets.google.com/ccc?key=0Al9zh8DjmU_RdGIzd0VLLTBpQVJuNVlHMlBWSDhKLXc&hl=en_GB#gid=8
> This helps us keep track or what works or doesn't.
> Raise any issues you find in our issue tracker and/or email list and/or IRC.
> We are hanging out on irc://freenode.net#osgeolive
> Cameron Shorter
> Geospatial Director
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Sourcehttp://www.lisasoft.com
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110805/499ded1e/attachment.html
More information about the Live-demo mailing list
