[Live-demo] Enhancement for Version number in Online Documentation
Cameron Shorter cameron.shorter at gmail.com
Tue Aug 9 07:33:51 EDT 2011
Frank,
As per one of your suggestions, I think that we are too close to 5.0
release, and as such shouldn't be introducing anything new like this
proposal. Lets come back and revisit for the next release.
On 09/08/11 20:39, Frank Gasdorf wrote:
> Update on this:
> Replacement within target URLs for images isn't possible yet. I found
> an other solution but this would lead to images without links in the
> first step. And here is what I plan to do:
> 1. enable extension "sphinx.ext.extlinks" in conf.py :
>     extensions = [ 'sphinx.ext.extlinks' ]
> 2. define an extlink for the download area in conf.py :
>     base_download_release_url=
>     'http://download.osgeo.org/livedvd/release/%(projectversion)s/%(variable)s
>     <http://download.osgeo.org/livedvd/release/%%28projectversion%29s/%%28variable%29s>'
>     % { 'projectversion': version,'variable':'%s'}
>     extlinks = {
>         'osgeolive-download': (base_download_release_url, 'filename ')
> 3. usage in download.rst page:
>        .. image:: ../images/download_buttons/download-vm.png
>          :align: left
>     :osgeolive-download:`osgeo-live-vm.7z: <osgeo-live-vm.7z>`
>     (|osgeo-live-vm-7z-size|)
> 4. same procedure for the md5 files :
>      :osgeolive-download:`osgeo-live-vm.7z.md5 <osgeo-live-vm.7z.md5>`
> I would suggest to rename the files that the version number is not
> included anymore. The download area has the dynamic version number
> taken from the VERSION.txt file (for example:
> <http://download.osgeo.org/livedvd/release/%%28projectversion%29s/>
> would lead into http://download.osgeo.org/livedvd/release/5.0/ if
>  VERSION.TXT has the line "5.0" in it )
> But in this case its necessary to change ISO naming procedure...
> Please have a look at the patch file coming along with this mail.
> pros:
>  * single point to define download URL's
>  * translators do not have to care about renaming
>  * no version update required in rst files anymore
> cons:
>  * update of shell scripts required for naming of ISO and 7z as well
> as md5 files (I have no chance to try the build with patched shell
> scripts)
>  * changes would be close to release day, maybe it's better to change
> after 5.0 release ...
> What do you think? Any opinions?
> Cheers, Frank
> 2011/7/7 Alex Mandel <tech_dev at wildintellect.com
> <mailto:tech_dev at wildintellect.com>>
>     >> Frank,
>     >> No there is not a deployment script which uploads the ISOs,
>     it's much
>     >> more complicated than you think since that url is actually
>     redirected to
>     >> a tool that then sorts people's downloads amongst the 5 mirrors.
>     >> The url as defined by the last release will be correct for the next
>     >> release.
>     >> Where:
>     http://download.osgeo.org/livedvd/release/[version]/osgeo-live-[version].iso
>     http://download.osgeo.org/livedvd/release/[version]/osgeo-live-mini-[version].iso
>     http://download.osgeo.org/livedvd/release/[version]/osgeo-live-vm-[version].7z
>     >> End up as:
>     >> http://download.osgeo.org/livedvd/release/5.0/osgeo-live-5.0.iso
>     >> I'll just have to remember to stick to that naming convention
>     when I'm
>     >> making new versions
>     > Correct me, when I'm wrong, I understood, that there is an
>     naming convention
>     > and if we use a pattern like the version replacement, we could
>     change the
>     > download.rst files in the way you summarized. So we don't have
>     to care about
>     > it in the future except the naming convention or uploading area
>     will change.
>     > Give me a go and I can update the download.rst files ...
>     > Cheers,
>     > Frank
>     Yes go ahead and make the change to create the links dynamically.
>     Those
>     are the correct naming conventions we intend to use. The url is
>     unlikely
>     to change in the foreseeable future aside from a new folder for each
>     version (which is accounted for in your method).
>     Thanks,
>     Alex
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110809/18972305/attachment-0001.html
More information about the Live-demo mailing list
