[Live-demo] Can we remove OpenJDK from OSGeo-Live?
Cameron Shorter cameron.shorter at gmail.com
Tue Aug 9 16:59:32 EDT 2011
OSGeo-LIve project contacts,
We are trying to find space on OSGeoLive, and expect that we can remove
OpenJDK, the free java implementation, as most applications seem to be
using the Sun JRE instead.
So from the java projects:
* Will you application be able to run without OpenJDK? (It seems that
rasdaman is the only application drawing it in)
* Will your application run with only Sun's JRE or do you require JDK as
well?
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
