[Live-demo] OSGeoLive proposal to replace Sun's default JRE/JDK with custom JRE
Cameron Shorter cameron.shorter at gmail.com
Tue Aug 9 21:12:31 EDT 2011
On 10/08/11 09:28, Jody Garnett wrote:
> Cameron if you were able to ensure the Sun JRE used included JAI /
> ImageIO / ImageIO-Ext then the udig project could make use of it
> directly (rather than using its own JRE as is done currently). An easy
> way to check would be to use the bundled JRE from the udig install
> script (rather than the sun jre) and see all the applications still work.
> The procedure to make one of these JRE+Extensions is here:
> http://udig.refractions.net/confluence/display/ADMIN/JRE+for+Linux - I
> can ask on udig-devel if they have made a script for this one yet.
> Jody
OSGeo-Live Java people,
Does Jody's suggestion make sense for your project?
Do you expect your project would work using UDig's custom java install?
Would you anticipate we might run into any stability issues?
Will this proposal help your project save any space?
Any other thoughts?
Please CC responses to live-demo at lists.osgeo.org
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
