[Live-demo] Re: Questions about 52nWPS, Java and OSGeo-Live
Cameron Shorter cameron.shorter at gmail.com
Tue Aug 9 22:21:15 EDT 2011
Thanks Bastian,
Forwarding your response onto the list for other java developers to
comment on...
On 10/08/11 12:12, Bastian Schäffer wrote:
> Hello Cameron,
> I am currently on vacation so please excuse my delayed response. 52n
> WPS makes use of the JRE installed but brings the JAI/ImageIO
> libraries with it. If these libraries are in the classpath, the could
> be removed manually (this has to be tested, they are needed for
> geotools. But if Jody is fine with it, I guess that it will be OK).
> However, this is some kind of effort to save 2mb or so. Not sure if
> this is worth it.
> Regards,
> Bastian
> On Wed, Aug 10, 2011 at 3:18 AM, <cameron.shorter at gmail.com
> <mailto:cameron.shorter at gmail.com>> wrote:
>     Bastian, Kristof,
>     Would you mind responding to this email on behalf of: 52nWPS
>     On 10/08/11 09:28, Jody Garnett wrote:
>         Cameron if you were able to ensure the Sun JRE used included
>         JAI / ImageIO / ImageIO-Ext then the udig project could make
>         use of it directly (rather than using its own JRE as is done
>         currently). An easy way to check would be to use the bundled
>         JRE from the udig install script (rather than the sun jre) and
>         see all the applications still work.
>         The procedure to make one of these JRE+Extensions is here:
>         http://udig.refractions.net/confluence/display/ADMIN/JRE+for+Linux
>         - I can ask on udig-devel if they have made a script for this
>         one yet.
>         Jody
>     OSGeo-Live Java people,
>     Does Jody's suggestion make sense for your project?
>     Do you expect your project would work using UDig's custom java
>     install?
>     Would you anticipate we might run into any stability issues?
>     Will this proposal help your project save any space?
>     Any other thoughts?
>     Please CC responses to live-demo at lists.osgeo.org
>     <mailto:live-demo at lists.osgeo.org>
>     Cameron Shorter
>     Geospatial Director
>     Tel: +61 (0)2 8570 5050 <tel:%2B61%20%280%292%208570%205050>
>     Mob: +61 (0)419 142 254 <tel:%2B61%20%280%29419%20142%20254>
>     Think Globally, Fix Locally
>     Geospatial Solutions enhanced with Open Standards and Open Source
>     http://www.lisasoft.com
Cameron Shorter
Geospatial Solutions Manager
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110810/91250a65/attachment.html
More information about the Live-demo mailing list
