[Live-demo] OSGeoLive proposal to replace Sun's default JRE/JDK with custom JRE
Eike Hinderk Jürrens e.h.juerrens at 52north.org
Wed Aug 10 01:53:52 EDT 2011
Hi!
Am 10.08.2011 03:12, schrieb Cameron Shorter:
> On 10/08/11 09:28, Jody Garnett wrote:
>> Cameron if you were able to ensure the Sun JRE used included JAI /
>> ImageIO / ImageIO-Ext then the udig project could make use of it
>> directly (rather than using its own JRE as is done currently). An
>> easy way to check would be to use the bundled JRE from the udig
>> install script (rather than the sun jre) and see all the applications
>> still work.
>> The procedure to make one of these JRE+Extensions is here:
>> http://udig.refractions.net/confluence/display/ADMIN/JRE+for+Linux -
>> I can ask on udig-devel if they have made a script for this one yet.
>> Jody
> OSGeo-Live Java people,
> Does Jody's suggestion make sense for your project?
> Do you expect your project would work using UDig's custom java install?
If the default xubuntu tomcat is able to use it, I see no problem ;-).
> Would you anticipate we might run into any stability issues?
I agree with the other statements in this or another thread nearby to go
for using java from the package tree.
> Will this proposal help your project save any space?
NO
> Any other thoughts?
All projects, especially the web service projects, should try to use the
default xubuntu environment and bring not their own stuff.
> Please CC responses to live-demo at lists.osgeo.org
Kind regards,
Eike
52° North Initiative for Geospatial Open Source Software GmbH
Martin-Luther-King-Weg 24
48155 Münster, Germany
E-Mail: e.h.juerrens at 52north.org
Fon: +49-(0)-251–396371-33
Fax: +49-(0)-251–396371-11
http://52north.org/
General Managers: Dr. Albert Remke, Dr. Andreas Wytzisk
Local Court Muenster HRB 10849
More information about the Live-demo mailing list
