[Live-demo] Re: Questions about kosmo, Java and OSGeo-Live
Sergio Baños Calvo
listas at saig.es
Wed Aug 10 02:44:18 EDT 2011
> On 10/08/11 09:28, Jody Garnett wrote:
>> Cameron if you were able to ensure the Sun JRE used included JAI /
>> ImageIO / ImageIO-Ext then the udig project could make use of it
>> directly (rather than using its own JRE as is done currently). An
>> easy way to check would be to use the bundled JRE from the udig
>> install script (rather than the sun jre) and see all the applications
>> still work.
>> The procedure to make one of these JRE+Extensions is here:
>> http://udig.refractions.net/confluence/display/ADMIN/JRE+for+Linux -
>> I can ask on udig-devel if they have made a script for this one yet.
>> Jody
> OSGeo-Live Java people,
> Does Jody's suggestion make sense for your project?
> Do you expect your project would work using UDig's custom java install?
> Would you anticipate we might run into any stability issues?
> Will this proposal help your project save any space?
> Any other thoughts?
> Please CC responses to live-demo at lists.osgeo.org
Hi to all.
If the Sun JRE used is 1.6.X and includes JAI, it should be ok for us. I
don't think that the other two additions (ImageIO / ImageIO-Ext) could
affect to Kosmo, but I'll check that everything is fine as soon as this
JRE is available in the LiveDVD.
We can then remove the bundled JRE and change the script in order to
save some space (50-60 Mb).
Regards,
Sergio Baños Calvo
Jefe de desarrollos
Sistemas Abiertos de Información Geográfica, S.L. (SAIG S.L.)
Tlfno. móvil: 685005960
Tlfno. fijo: (+34) 954788876
E-mail: sbc at saig.es
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110810/4baefde8/attachment.html
More information about the Live-demo
