[Live-demo] Re: [OSGeo] #750: ushahidi doesn't connect to DB during quickstart setup
OSGeo trac_osgeo at osgeo.org
Fri Aug 19 09:11:49 EDT 2011
 Reporter:  camerons      |        Owner:  live-demo@…
     Type:  defect        |       Status:  closed
 Priority:  normal        |    Milestone:
Component:  LiveDVD       |   Resolution:  fixed
 Keywords:  5.0 ushahidi  |
Comment(by hamish):
 actually the problem was in install_mysql.sh. The seeding of the admin pw
 was failing because the server's package name changed with this version of
 ubuntu and the value in /var/cache/debconf/password.txt was empty. So when
 install_ushahidi.sh tried to automatically set up the db it would fail, as
 seen in Alex's build log.
 hopefully fixed by r6960.
 Hamish
 ps- re. the new quickstart hint: are the instructions valid as there is no
 root password? (you need to do `sudo su` to get there)
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/750#comment:2>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
