[Live-demo] [OSGeo] #768: osgEarth: quickstart example doesn't work
OSGeo trac_osgeo at osgeo.org
Sun Aug 21 03:05:03 EDT 2011
 Reporter:  hamish   |       Owner:  live-demo@…
     Type:  task     |      Status:  new
 Priority:  major    |   Milestone:
Component:  LiveDVD  |    Keywords:  5.0 osgEarth
 if you follow the steps in the osgEarth quickstart,
 export OSG_FILE_PATH=/usr/share/osgearth
 osgearth_viewer --window 50 50 900 700 /usr/share/osgearth/maps/srtm.earth
 it gives an error about `Warning: could not find plugin to load objects
 from file "50"` then `[osgearth] Unable to load earth model.` and the
 usage text before returning to the command prompt.
 Hamish
 ps- we can put that export line in /etc/profile.d/osgEarth.sh if you like,
 then add the demo viewer as a menu item..
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/768>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
