[Live-demo] Re: [OSGeo] #769: R: GRASS plugin doc does not display completely
OSGeo trac_osgeo at osgeo.org
Mon Aug 22 04:46:17 EDT 2011
 Reporter:  darkblueb  |       Owner:  live-demo@…
     Type:  defect     |      Status:  new
 Priority:  normal     |   Milestone:
Component:  LiveDVD    |    Keywords:  R, grass, 5.0
Comment(by rbivand):
 Replying to [comment:1 hamish]:
 > Hi,
 > /usr/local/lib/R/site-library/spgrass6/doc/spgrass6_0.3.pdf
 > neither `okular` or `gv` also on the disc views it well either, although
 I suspect they all use the same ghostscript library.
 > (okular is really quite a nice program)
 > moreover, my local copy of it is also corrupted, so this problem is
 nothing to do with the live dvd.
 > adding Roger to the cc for further advice..
 > Hamish
 Sorry, the PDF files seem to have been trashed at some stage. I've
 uploaded the original copies from the OSGeo Journal etc. again to SVN on
 R-Forge.R-project.org, project rspatial, module spgrass6.
 https://r-forge.r-project.org/src/contrib/spgrass6_0.7-4.tar.gz will
 contain the correct versions from early on August 23 (CEST). I will not be
 releasing this version to CRAN until I get some confirmation that major
 changes made there (and committed to SVN) do not wreck anyone's scripts.
 If the correct PDFs are needed for the LiveDVD now, please pull them from
 the SVN repository on R-Forge, and check that they are OK.
 Roger
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/769#comment:2>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
