[Live-demo] [OSGeo] #772: rasdaman build errors in 5.0rc2
OSGeo trac_osgeo at osgeo.org
Mon Aug 22 20:35:41 EDT 2011
 Reporter:  hamish    |       Owner:  live-demo@…
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:
Component:  LiveDVD   |    Keywords:  5.0, rasdaman
 make[1]: Leaving directory
 `/tmp/build_rasdaman/rasdaman_data/DataImport/demodata'
 make -C nir import;   make -C lena import;   make -C mowglie import;
 make -C timeseries import;   make -C demodata imp
 ort;
 make[1]: Entering directory
 `/tmp/build_rasdaman/rasdaman_data/DataImport/nir'
 echo "rasql -q 'insert into NIR values inv_tiff($1)' --file nir.tiff
 --user rasadmin --passwd rasadmin --port 7001 -d RA
 SBASE"
 rasql -q 'insert into NIR values inv_tiff()' --file nir.tiff --user
 rasadmin --passwd rasadmin --port 7001 -d RASBASE
 rasql -q 'insert into NIR values inv_tiff($1)' --file nir.tiff --user
 rasql: rasdaman query tool v1.0, rasdaman v8 -- generated on 22.08.2011
 16:24:27.
 opening database RASBASE at localhost:7001...ok
 fetching type information for GreyString from database, using readonly
 transaction...ok
 reading file nir.tiff...ok
   constant 1: GMarray
   Oid...................:
   Type Structure........:
   Type Schema...........: marray< char >
   Domain................: [0:6195321]
   Base Type Schema......: char
   Base Type Length......: 1
   Data format.......... : Array
   Data size (bytes).... : 6195322
 Executing update query...rasdaman error 0: Exception: Transfer Failed
 aborting transaction...ok
 rasql done.
 make[1]: *** [import] Error 255
 echo "rasql -q 'insert into lena values inv_tiff($1)' --file lena.tiff
 --user rasadmin --passwd rasadmin --port 7001 -d RASBASE"
 rasql -q 'insert into lena values inv_tiff()' --file lena.tiff --user
 rasql -q 'insert into lena values inv_tiff($1)' --file lena.tiff --user
 rasql done.
 `/tmp/build_rasdaman/rasdaman_data/DataImport/lena'
 scripts/insertbin localhost 7001 rasadmin rasadmin RASBASE NN3_10
 Data/NN3_10.dat
 scripts/insertbin: error while loading shared libraries: libmfhdf.so.0:
 cannot open shared object file: No such file or
 directory
 scripts/insertbin localhost 7001 rasadmin rasadmin RASBASE NN3_11
 Data/NN3_11.dat
 directory
 make[1]: *** [import] Error 127
 `/tmp/build_rasdaman/rasdaman_data/DataImport/timeseries'
 it is unknown to me if any of the above are fatal / harmless.
 for the last one, perhaps installing the libhdf4-0 package is needed?
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/772>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
