[Live-demo] [OSGeo] #773: sahana web2py error in 5.0rc2 log
OSGeo trac_osgeo at osgeo.org
Mon Aug 22 21:04:11 EDT 2011
 Reporter:  hamish   |       Owner:  live-demo@…
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:
Component:  LiveDVD  |    Keywords:  5.0, sahana
 2011-08-22 14:20:05 (154 KB/s) - `/tmp/build_sahana/web2py_src-1.96.4.zip'
 saved [7127316/7127316]
 You have not informed bzr of your Launchpad ID, and you must do this to
 write to Launchpad or access private data.  See "bzr help launchpad-
 login".
 S3 Debug: s3utils: XLRD not installed, Spreadsheet Importer not available.
 Warning: Running Web2Py < 3566, so Scheduled Tasks aren't available -
 please upgrade
 web2py Web Framework
 Created by Massimo Di Pierro, Copyright 2007-2011
 Version 1.96.4 (2011-06-07 21:08:15)
 Database drivers available: SQLite3, pymysql, PostgreSQL
 please upgrade
   File "web2py.py", line 19, in <module>
     gluon.widget.start(cron=True)
   File "/usr/local/lib/web2py/gluon/widget.py", line 808, in start
     import_models=options.import_models, startfile=options.run)
   File "/usr/local/lib/web2py/gluon/shell.py", line 200, in run
     execfile(startfile, _env)
   File "applications/eden/static/scripts/tools/compile.py", line 33, in
 <module>
     compile_application(folder)
   File "/usr/local/lib/web2py/gluon/compileapp.py", line 506, in
 compile_application
     os.mkdir(os.path.join(folder, 'compiled'))
 OSError: [Errno 13] Permission denied: 'applications/eden/compiled'
                       addgeometrycolumn
  public.gis_location.the_geom SRID:4326 TYPE:GEOMETRY DIMS:2
 (1 row)
 Enabling module proxy.
 no idea if that is fatal or harmless, ..
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/773>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
