[Live-demo] Re: [OSGeo] #775: MapServer does not support WMS
OSGeo trac_osgeo at osgeo.org
Tue Aug 23 06:46:05 EDT 2011
 Reporter:  olt          |       Owner:  live-demo@…
     Type:  enhancement  |      Status:  new
 Priority:  major        |   Milestone:
Component:  LiveDVD      |    Keywords:  mapserver, 5.0
Changes (by hamish):
  * keywords:  mapserver => mapserver, 5.0
  * priority:  normal => major
Comment:
 quote the June email:
 I'm creating an example configuration for MapProxy for the LiveDVD and I
 found out that the Itasca Demo from Mapserver is not configured properly.
 I get the following error if I make WMS requests:
 <!DOCTYPE ServiceExceptionReport SYSTEM
 "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
 <ServiceExceptionReport version="1.1.1">
 <ServiceException code="InvalidSRS">
 msWMSLoadGetMapParams(): WMS server error. Cannot set new SRS on a map
  that doesn&#39;t have any projection set. Please make sure your mapfile
  has a projection defined at the top level.
 </ServiceException>
 </ServiceExceptionReport>
 It also doesn't work in uDig for example. It works fine if I uncomment the
 PROJECTION part in the itasca.map file. Can someone update the example for
 the next LiveDVD release? (and add a author/maintainer comment to the
 install_mapserver.sh :)
 Regards,
 Oliver
 the source of the data is stored in gisvm/trunk/app-
 data/mapserver/workshop/mapserver-itasca-ms60.zip
 so to fix it we can just unzip, edit, and rezip that.
 here is a possible patch, what do you think?
 --- itasca.map.ORIG     2011-08-23 22:40:56.163637724 +1200
 +++ itasca.map  2011-08-23 22:42:13.855650009 +1200
 @@ -16,17 +16,17 @@
    # Projection definition, consult the PROJ.4 documentation for parameter
 discussion
 -  # PROJECTION
 -  #   "proj=utm"
 -  #   "ellps=GRS80"
 -  #   "zone=15"
 -  #   "north"
 -  #   "no_defs"
 +PROJECTION
 +  "proj=utm"
 +  "ellps=GRS80"
 +  "zone=15"
 +  "north"
 +  "no_defs"
    #   OR:
    #   "init=epsg:26915"
 -  # END
 +END
    # Start of symbol definitions (we're only using a few)
 n.b. the proj4 "+north" term doesn't exist/is a no-op, only utm "+south"
 counts.
 I assume the "OR" was comments not code. I don't know if it matters, but
 also note the specified proj terms do not set the datum (NAD83) while the
 EPSG version does.
 Hamish
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/775#comment:1>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
