[Live-demo] finding that last 100mb
Manuel Grizonnet manuel.grizonnet at gmail.com
Wed Aug 24 11:49:02 EDT 2011
I've just commented in install_otb.sh the download of image samples use in
the softawre guide . It will save 20 Mo I think.
HIH
2011/8/24 Hamish <hamish_b at yahoo.com>
> Hi,
> so the 5.0rc3 build came in small enough to fit on a USB stick
> but 100mb too big to make the full DVD without sacrificing
> some of our installers & usb user-space.
> We are frozen in critical-bug-fix only mode now, but as not
> physically fitting on a DVD is kinda important, I propose to
> remove the following packages to free up as much space as we
> can muster.
> So make lots of noise quickly if you have any objection or
> worry it may cause problems big or small. I suspect that
> they are just left over from the build process.
> 75.805 MB        openjdk-6-jre-headless   [rasdaman]
> 11.543 MB        python2.7-dev   <=== req'd ?   [sahaha]
> 11.055 MB        python2.6-dev   <=== req'd ?   [mapfish]
> 11.551 MB        libsane   <== scanner lib used by rm'd gimp
> also, I do not propose to touch it for this cycle, but I wonder,
> do we need to keep Sun's JDK if we have the JRE?
> 59.938 MB        sun-java6-jdk
> 13.980 MB        sun-java6-jre
> To aid in testing I'd ask that any testers manually remove the
> above pkgs before testing:
>  sudo apt-get remove openjdk-6-jre-headless \
>   python2.6-dev python2.7-dev libsane
> thanks,
> Hamish
> [0] http://live.osgeo.org/dev/build
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Manuel
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110824/f5140b6d/attachment.html
More information about the Live-demo mailing list
