[Live-demo] [OSGeo] #778: regression test
OSGeo trac_osgeo at osgeo.org
Thu Aug 25 21:30:46 EDT 2011
 Reporter:  jive         |       Owner:  live-demo@…
     Type:  enhancement  |      Status:  new
 Priority:  minor        |   Milestone:  Unplanned
Component:  LiveDVD      |    Keywords:  qa
 During the run up the the latest release; one of the only ways to make
 progress was to watch people on IRC manually go through the ISO contents
 and type "ls -a" in each directory.
 With that in mind I would like to propose a "regression test" for the
 osgeo live project. This is based on the cheap and easy way of making
 regression tests used for Java projects (where you take all the test logs
 into a single file; and then do a diff from the previous nightly build;
 and email the diff to the developers list).
 Note this is a proper regression test - it does not detect failure - only
 changes. Even if you just ignore the emails and sort them into a folder -
 you can still sift through the emails at a later date in order to sort out
 exactly when things changed.
 So here is the plan:
 1) do we have a nightly or weekly build resulting in an ISO?
 2) write a script to mount the ISO; and perform an "ls -a -R >
 osgeolive20110923.txt"
 3) continue the script to perform a diff between todays contents; and the
 day before
 4) email the diff to the developer list
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/778>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
