[Live-demo] Re: [OSGeo] #784: Error message when exiting pgadmin3
OSGeo trac_osgeo at osgeo.org
Fri Aug 26 20:59:33 EDT 2011
 Reporter:  rouault  |       Owner:  live-demo@…
     Type:  task     |      Status:  new
 Priority:  major    |   Milestone:
Component:  LiveDVD  |    Keywords:  5.0, pgadmin3
Changes (by hamish):
  * keywords:  => 5.0, pgadmin3
  * priority:  normal => major
Comment:
 5.0rc5 mini ISO: file is editible by the user. but if you try to 'rm
 ~/.pgadmin3' on the command line you get the same error message.
 it seems hardlinked to another copy on the disc at /usr/local/share/gisvm
 /app-conf/postgis/pgadmin3
 solution: edit ~/.pgadmin3 on the master VM before build_iso.sh so they
 are different. we can probably adjust one of the window placement config
 options Height=524 -> Height=525 without much harm.
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/784#comment:1>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
