[Live-demo] Re: [OSGeo] #793: translate geospatial menus
OSGeo trac_osgeo at osgeo.org
Tue Aug 30 18:38:08 EDT 2011
 Reporter:  hamish   |       Owner:  live-demo@…
     Type:  task     |      Status:  new
 Priority:  normal   |   Milestone:
Component:  LiveDVD  |    Keywords:  5.5, i18n, menus
Comment(by hamish):
 Replying to [comment:2 camerons]:
 > Hamish,
 > I suggest that we build the menus from a file in subversion,
 we already do. see the gisvm/desktop-conf/xfce/*.directory files.
 > which can be maintained by the various translation communities over
 time.
 I just meant to commit the initial bunch. After that it should be obvious
 where new translations should go.
 > If we put the source translation file into say
 > doc/<lang>/menu_names.csv file, then it will fit quite well into our
 > translation process.
 Shrug, sure, why not. I'd suspect that would be some duplication of
 effort, and the categories won't really change through time. However,
 where to apply them might change so a single+central location for the
 translators to quickly run through could be helpful for them.
 processing a multi-language utf-8 file with grep et al might be a
 nightmare to have them apply by script, but I'm sure we can figure
 something out. On the other hand, for that reason it may just be simpler
 to point people to the desktop-conf/ dir.
 pros, cons....
 best,
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/793#comment:3>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
