[Live-demo] What version of applications should we be installing on OSGeo-Live 5.5?
Brian Hamlin maplabs at light42.com
Fri Dec 30 03:34:47 EST 2011
If gvSIG and GeoServer both work with OpenJDK
and uDig has its own java runtme
I suggest it is *possible* to make the change to OpenJDK this time
around
I also am actively seeking Java-wizard volunteers to keep this smooth!
best regards from Berkeley, California
   -Brian
Brian Hamlin
GeoCal
OSGeo California Chapter
415-717-4462 cell
On Dec 21, 2011, at 11:45 PM, Frank Gasdorf wrote:
> I'll try, its a bit time critical, because between the 2nd day after
> Christmas and New Year I'm totally offline ;)
> I'm going to start with geoserver 2.1.3 and if finished I'll go over
> to udig 1.3.1, but in this case we have to update the docs
> (screenshots with palette tools ;)) and go through the walkthrough as
> well.
> here is the plan:
> * update scripts for geoserver 2.1.3 and test it
> * update scripts for udig 1.3.1 and check that everything is fine (I
> guess we ship it with the bundled JRE so we do not have care about the
> OpenJDK discussion right now
> * if everything went well, update the docs
> Would be great to get support for several steps, reviews etc. Its
> warmly welcome!!!
> Cheers,
> Frank
> @Cameron: I'm ok with your suggestion to be a point of contact for
> geoserver in the the osgeo live project. Who was it yet?
> 2011/12/22 Jody Garnett <jody.garnett at gmail.com>:
>> Frank are you able to update uDig to 1.3.1 as well?
>> Jody Garnett
>> On Wednesday, 21 December 2011 at 6:58 AM, Frank Gasdorf wrote:
>> Cameron, thank you for starting the engines ;)
>> Currently the geoserver project started to release 2.1.3, its a minor
>> version number higher that the version that is on the current 5.0
>> Live
>> DVD. I would like to have 2.1.3 on the 5.5 Release because of the
>> completed German translation of the core modules and the upcoming
>> FOSSGIS Event in Germany next March.
>> I will update and test the installer scripts for the OSGeo project if
>> the geoserver release is out. Everybody is invited to test and
>> contribute ;)
>> Cheers,
>> Frank
>> 2011/12/16 Cameron Shorter <cameron.shorter at gmail.com>:
>> Hi all,
>> Over the Christmas/New Year break, we intend to start the OSGeo-
>> Live build
>> process for the next 5.5 release and would like to know which
>> version of
>> each application we should include on OSGeo-Live.
>> For the application(s) which you are responsible for, could you
>> please email
>> me with the version that you expect should be installed.
>> If you will be changing the version of your application, could you
>> please
>> start thinking about updating the installers script.
>> Our key milestones are:
>> * 7 Jan 2012: Feature Freeze (installer scripts in place)
>> * 4 Feb 2012: OSGeo-Live to UAT (all bugs out of installers and
>> applications)
>> * 25 Feb 2012: Final image sent to the printers
>> Cameron Shorter
>> Geospatial Solutions Manager
>> Tel: +61 (0)2 8570 5050
>> Mob: +61 (0)419 142 254
>> Think Globally, Fix Locally
>> Geospatial Solutions enhanced with Open Standards and Open Source
>> http://www.lisasoft.com
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://live.osgeo.org
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo mailing list
