[Live-demo] 4.5alpha1 Build has started
Hamish hamish_b at yahoo.com
Tue Feb 1 03:01:02 EST 2011
Alex wrote:
> Logs are up,
> Normal Build - Probably will not make an iso, could post
> the vm image.
> http://osprey.ucdavis.edu/downloads/osgeo/gisvm/4.5alpha1/4.5alpha1.tar.gz
lets see...
install_sahana.sh fails because "echo -e" is a bashism.
solution is easy, just remove the -e and the \n.
sahana: wget should use "--progress=dot:mega" mode, and tar
shouldn't be run in verbose mode, just xzf. same for 'unzip -q'
that installer comes near the beginning, and once sources.list
is broken nothing else works right.
ah well, we knew there would be a few bashism issues there,
try try again.
Hamish
More information about the Live-demo mailing list
