[Live-demo] Rasdaman build error?
Cameron Shorter cameron.shorter at gmail.com
Sat Feb 19 14:34:25 EST 2011
Hamish, thanks for the review.
Michael, Peter,
Are you able to address this ASAP?
I've very keen to have rasdaman working 100% before we make our first
release candidate for testing, due on 21 Feb, in 24 to 48 hours.
Please let us know as soon as you are finished, so that a 2nd person can
test the install script in the latest VM.
On 20/02/11 00:28, Hamish wrote:
> Hi, I've now had a change to review the script and see why the
> icons didn't make it into the menu.
> the following changes are needed in the rasdaman installer:
> -space on the disc is extraordinarily tight. please remove -dev packages
>   when you are done with them.
> -please use /tmp/build_rasdaman/ for your git downloads and build, not the
>   base build dir [./bin/]. Grep many/most other install scripts for examples.
> -to keep the noise down in the live disc's build log, for large files please
>   use wget's --progress=dot:mega option. (-c is not appropriate for unversioned
>   filenames, but -N can help there (n.b. -N doesn't work in combo with -O))
> -do not use "chmod 777 -R". set group ownership to the "users" or "www-data"
>   group and change to g+w. Grep other scripts for examples.
> -use the --quiet flag when you run psql to avoid cluttering the build log.
> -icon files currently double-set the Categories= setting.
> -for the GIS menu to include your app you must copy the .desktop files
>   from /usr/share/applications/ into $USER/Desktop/.
> -for consistency all *.desktop icon files should probably be lowercased,
>   although I've just modified the menu-building script to work with all your
>   icon files in the state they are in now. (but they still need to be copied
>   over to the user's Desktop/ to be included in the menus; see packaging
>   instructions on the wiki*)
> [*] http://wiki.osgeo.org/wiki/Live_GIS_Add_Project#Packaging_conventions
> thanks,
> Hamish
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
