[Live-demo] ORFEO Toolbox in OSGeoLive?
Manuel Grizonnet manuel.grizonnet at gmail.com
Fri Jan 14 04:04:09 EST 2011
Hi Cameron,
I addes an entry in the #Status document about orfeo toolbox.
The install script for OTB  will be very simple I think :
*sudo aptitude install add-apt-repository
sudo add-apt-repository ppa:otb/orfeotoolbox-stable*
*sudo aptitude update  *
*sudo aptitude install otb otbapp monteverdi*
I'll send a script for orfeo based on the mapserver script soon.
Regards,
Manuel
2011/1/12 Cameron Shorter <cameron.shorter at gmail.com>
>  Thank you Manual for these clarifications.
> I'm heartened by all your answers, and I'm +1 for including OTB on
> OSGeo-Live.
> Assuming that there are no other questions or objections from our
> community, I'd encourage you to start packaging OTB as per:
> http://wiki.osgeo.org/wiki/Live_GIS_Add_Project
> If you wish to make the next release, can you please aim to have install
> script and Overview and Quickstart text complete by 31 January.
> On 13/01/2011 4:41 AM, Manuel Grizonnet wrote:
> Hi all,
>  I answer below to questions about OTB before moving forward:
> 1. OSGeo-Live is targeted at applications that people can use rather
> than libraries that are included into other applications. Does ORFEO
> Toolbox have a user interface (possibly command line interface) that a
> user can interact with and try out ORFEO Toolbox?
>  ->Yes the software Monteverdi based on OTB provide a user interface and
> an architecture which allows building processing chains by selecting modules
> from a set of menus. It supports raster and vector dataThe architecture
> takes advantage of the streaming and multi-threading capabilities of the OTB
> pipeline. It also uses cool features as processing on demand and automagic
> file format I/O. The application is called Monteverdi, since this is the
> name of the Orfeo composer<http://en.wikipedia.org/wiki/Claudio_Monteverdi>
> .  The application is also packaged on Ubuntu, you can find more
> informations here : http://www.orfeo-toolbox.org/otb/monteverdi.html
> Moreover the otb-app package provides OTB processing chain (command line
> interface) which are also accessible through user interface (standalone qt
> application or qgis plugins)
> 2. OSGeo-Live is memory and disk constrained.
> Can ORFEO Toolbox run in 512 Meg or RAM?
>  ->Yes, we already provide in the past Live OTB which works on this type
> of platforms. The application monteverdi was developped in the frame of
> capacity building activities and it works on PC with memory and disk
> constrained (512 Mo of RAM is enough to run the application and do basic
> processing).
> How much disk space will be required to install ORFEO Toolbox and a
> suitable example application.
>  -> otb package 10 Mo, monteverdi package 10 Mo, otb-app 15 Mo
> What datasets would be required for a demonstration? Can you make use of
> the naturalearth dataset already installed, or would you need something
> else?
> http://wiki.osgeo.org/wiki/Live_GIS_Add_Project#Example_Datasets
>  -> I do not know this dataset, I think that we can use this dataset. We
> provide also on our repository extract of remote sensing data which are used
> as examples in the software guide and in the OTB tutorial.
> http://hg.orfeo-toolbox.org/OTB-Data/
> Our documentation (description of algorithms, input images, examples and
> results) are automatically generated each time when we update the software
> guide to ensure that results which appear in the documentation are results
> provided by the library.
> We can pointed out interesting "Toy example" if you want which will give an
> overview of OTB functionnalities on the Live DVD?
> 3. You mention that ORFEO is in OSGeo incubation. I can't see ORFEO
> listed at http://osgeo.org . Have you started incubation, or are you on
> the waiting list to start incubation?
>  -> Sorry, I only open a ticket on the OSGeo website to start the
> incubation process for now...
> 4. Stability is very important to us on OSGeo-Live. Do you have a bug
> free, stable release, which has been rolled out to production in a
> number of locations?
>  -> The last OTB release 3.8.0 and monteverdi 1.6.0 are the latest stable
> release. OTB validation is mainly driven by a platform of automatic tests
> (based on cmake, ctest and cdash). The library is continuously and
> intensively tests on numerous platforms. There are more than 1500 tests
> currently in the library...
> http://dash.orfeo-toolbox.org/index.php?project=OTB
> 5. I notice the CeCILL licence you use is not listed on OSI list of
> licences. Has license been discussed and resolved on the
> OSGeo-Incubation list?
>  -> I am not aware of any discussions about the licence, Cecill is a free
> software license (adapted to french legal matter) compatible with GPL :
> http://en.wikipedia.org/wiki/CeCILL
> 6. Do you have a person (maybe yourself?) prepared to volunteer to be
> the OSGeo-Live representative, who will take responsibility for liaising
> between the project and OSGeo-Live and make sure that scripts and
> documentation are updated for each release.
>  -> No problem for liaising between OSGeo and OTB. There is also an OTB
> packages team on launchpad with contacts : https://launchpad.net/~otb<https://launchpad.net/%7Eotb>
>  Regards,
>  Manuel
> 2011/1/11 Manuel Grizonnet <manuel.grizonnet at gmail.com>
>> Hi Johan,
>>  I think that's some words in your answers are missing... "it is already
>> packaged and...???"
>>  2011/1/11 Johan Van de Wauw <johan.vandewauw at gmail.com>
>>> Since
>>>  On Tue, Jan 11, 2011 at 11:38 AM, Manuel Grizonnet <
>>> manuel.grizonnet at gmail.com> wrote:
>>>>  The toolbox (and also related projects) are also provided as binary
>>>> packages for Windows, Mac and recently also on Linux Platforms. An OTB
>>>> repository is available on launchpad.net for Ubuntu platforms
>>>> (9.10,10.4,10.10) and also for OpenSuse platforms.
>>>  it is already packaged and
>>>>  OTB is under incubation for OSGeo Project.
>>>  I think it would be a very good idea to include OTB on the live disk.
>> Manuel
> Manuel
> Live-demo mailing list
> Live-demo at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
> Cameron Shorter
> Geospatial Solutions Manager
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Sourcehttp://www.lisasoft.com
Manuel
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110114/30c2de50/attachment-0001.html
More information about the Live-demo mailing list
