[Live-demo] ORFEO Toolbox in OSGeoLive?
Manuel Grizonnet
manuel.grizonnet at gmail.com
Mon Jan 24 12:47:32 EST 2011
Hi all,
the SVN access is to the osgeolive repository works, thank you.
-I've updated the install script for otb.
-I've made few modifications to the overview and the quickstart pages
(taking into account Cameron's comments).
Regards,
Manuel
2011/1/21 Manuel Grizonnet <manuel.grizonnet at gmail.com>
> Hi Cameron, thank's for the review. All your comments make sense.
> I'll test the svn access and update the documentation next week.
> Thank's again.
> Manuel
> 2011/1/21 Cameron Shorter <cameron.shorter at gmail.com>
> Manuel,
>> Thank you for your OTB docs.
>> Here is a review of the Overview docs. Can you please see if my comments
>> make sense, and update text if appropriate.
>> There are a couple of minor grammar comments I'll address again after you
>> have a look at this first round of comments.
>> Image Processing¶
>> ORFEO Toolbox library (OTB) is a high performance library for image
>> processing targeted on remote sensing.
>> *Cameron: I suggest a minor rewording:
>> ORFEO Toolbox library (OTB) is a high performance [geographic image
>> processing] library targeted on targeting remote sensing.*
>> *Cameron: Could you please include 1 to 3 sentences describing what Image
>> Processing is and maybe a sentence describing what remote sensing is. What
>> are the sort of things that Image Processing is all about? The reader is
>> likely to know very little about geospatial, and won't know what the unique
>> issues are regargd They may be a manager, they may be a general programmer
>> without a geospatial background. "Geospatial Image Processing is the act of
>> ... It is typically used to ... "*
>> OTB has been funded the French Space Agency (CNES) in the frame of the
>> Methodological Part of the ORFEO Accompaniement Program
>> *Cameron: Again, I suggest generalising the description above. It is good
>> to mention the French Space Agency, but is probably too detailed to mention
>> specific programs as 98% of new users won't be interested in it.
>> to prepare, accompany and promote the use and the exploitation of the
>> images derived from Pleiades (PHR) and Cosmo-Skymed (CSK) systems.
>> *Cameron: You might want to describe the types of images collected, and
>> use as an example to illustrate your description above.
>> *It has been actively developed since 2006.
>> Cameron: Can add more words about the stability of OTB. Maybe say that it
>> has been "deployed in production since ...". Maybe mention the breath of
>> high profile users of OTB?
>> OTB is distributed as an open source library of image processing
>> algorithms. OTB is based on the medical image processing library ITK and
>> offers particular functionalities for remote sensing image processing in
>> general and for high spatial resolution images in particular.
>> Core Features
>> - image access: optimized read/write access for most of remote sensing
>> image formats, meta-data access, visualization;
>> - orthorectification and Map Projection
>> - calibration functionnalities
>> - *Cameron: Say either "calibration" or "calibration functions"*
>> - image fusion
>> - filtering: blurring, denoising, enhancement;
>> - feature extraction: interest points, alignments, lines;
>> - object detection
>> - image segmentation: region growing, watershed, level sets;
>> - classification: K-means, SVM, Markov random fields;
>> - object-based image analysis
>> - geospatial analysis
>> - SAR data analysis
>> - change detection.
>> Details¶
>> *Website:* http://www.orfeo-toolbox.org/
>> *Licence:* CeCILL
>> *Cameron: As CeCILL is not directly OSI approved, I suggested adding
>> "(CeCILL is compatible with GPL and enhanced to address French law)"*
>> *Software Version:* 3.8.0
>> *Supported Platforms:* Linux, Mac, Windows
>> *API Interfaces:* C++
>> *Commercial Support:* http://www.osgeo.org/search_profile
>> Quickstart¶
>> - Quickstart documentation
>> *Cameron: I've only quickly skimmed the Quickstart and haven't had time
>> to do a proper review. However my first stand-out comment is that the
>> Quickstart should not be describing the C++ interface as part of the OTB
>> library. (In general, our users will not be programmers.) Instead just
>> include the Monteverdi description (probably expanded) *
>> Cameron Shorter
>> Geospatial Director
>> Tel: +61 (0)2 8570 5050
>> Mob: +61 (0)419 142 254
>> Think Globally, Fix Locally
>> Geospatial Solutions enhanced with Open Standards and Open Sourcehttp://www.lisasoft.com
> Manuel
Manuel
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110124/e616e8a1/attachment.html
More information about the Live-demo
