[Live-demo] Has the process to update the status sheet changed?
Javi Sanchez jsgisdev at gmail.com
Tue Jun 7 17:38:26 EDT 2011
Thank you Cameron,
I've given it a try again, and now I get the message:
".. svn: '.' is not a working copy..."
Either if I run it from /bin directory or not.
I have checked the result, and everything seems to be correct, except
for the content of the INSTALL SCRIPT info, that is not generated.
I'm afraid I don't have the skills to debug the script.
Regards,
Javi Sánchez
On 06/03/2011 10:23 PM, Cameron Shorter wrote:
> Javi,
> Yes, I have updated the spreadsheet but it is possible you didn't seem
> my email about it. I'll follow this up with an email to all the
> translators to discuss.
> You have also picked up a bug in the extract_doc_versions.sh script.
> (It previously needed to be run from the bin/ directory). I've fixed
> it now, so should work properly.
> PS, great to see you kick-starting the translations again.
> On 04/06/11 05:07, Javi Sanchez wrote:
>> Hi,
>> We are trying from 'Spanish Language OSGeo Chapter' to re-start
>> translation activities.
>> I've seen there has been changes in the spreadsheet.
>> I just wonder if the process to update the status sheet is still
>> working as defined in [1], as I'm afraid I gave up doing it some
>> months ago :-( ...
>> When I run the script, I get the following message: cd: 76: can't cd
>> to bin/../bin and I'm not sure I'm getting the proper data to copy to
>> the sheet.
>> Thanks for any help,
>> Javi.
>> [1] http://wiki.osgeo.org/wiki/Live_GIS_Translate
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo mailing list
